Melbourne Night Cruise 27th September Friday Night
  • Replies 157
it would depend on what time it starts as i have to go to a gfs friends bday party for an hour... can meet up at one of the meeting points after that tho...
As I said in the other thread... If my car's back on the road *crosses fingers*, I'll be there with bells on...
Blah about what the missus says, she should be at home with dinner ready for you when you get home! *ducks* :rolleyes:
matt
Originally posted by OOHSAM
Heheh you guys are clowns.
I've got a few meeting points in mind, depending on how many pplz come down, we'll see how it goes...
i know i am i said u r so what is he?
Ok so it looks like we wont be having any more ppl coming than that, the post has been up for a while, 11 is ok though, Ill be letting you guys know a destiantion and a place of meeting point this week, im working on it however with my new job, its been kinda hard...i just started today and i dont have net acces, i dont efven have my desk yet still in sorta training, but its good none the less, be assued, i will advise you of what is happening....
Sam
depending on what time u guys are having it i should be able to make it after 9pm... altho funkehmunkeh im sure thats past ur bedtime so i'll se u on another cruise :)
:D
don't make me pull out the kiwi jokes man... coz you know i'll bring the beat down on your ass with kiwi jokes.
btw my resume's ready :D now I gotta find a DOC to PDF converter so my fonts stay intact.
oh please... u know ur stretching the attempted beat down when all u can bring are kiwi jokes.... things ive heard since i got here and generally things that backfire in the joke tellers face when i reply to them... im quick whitted... u'll need more than a few sheep jokes to topple me.. :)
the only ass thats gonna get a beat down is urs, my little baboon assed friend.
**EDIT
u still got my email address?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
