  • Replies 64
Posted Images
Perhaps although i doubt it would have saved the diff, huge RPM launches on sticky rubber - something was gonna give.
Mind you that diff must have seen at least triple figure launches in its life. So it's done good service for a stocker
Thats some good info there on what a stocko is capable of.
Bloody cheaters, wish I had this traction thing with high RPM launch, stupid physics.
Gotta make use of all the advantages you can get!
i have a gtr 32 with two n1's 345hp at the wheels, ride clutch out a little then dump at 5000 and i get a awsome launch, and chew a bit of my clutch, but would rather that than my gearbox. the problem with you guys bogging down is your not getting boost build up, only revs, ride the clutch a bit get some load on the turbos going and youl be right, dont just rev.
If i dial up 4500 and jump off the clutch at a 100% throttle press, it's smoking all 4 wheels no problems.
Rears start turning and then the fronts kick in and it's a smokeshow!
Month or so ago @ MotiveDVD Drag Battle i had Hoosier Drag Radials on - combined with PowerFC Pro.
Set the limiter to 7300 - foot to the floor and let the clutch go and hang on. Happy in pants launches for 2 days. I expected to break a gearbox for sure... must have done at least 30 launches like that... but no... the gearbox held fine
Eventually destroyed the front diff (which is much worse), so i'd not reccommend such action if you don't like breaking stuff hehe.
Nismo diff on the way, and then i'll be out there doing it again :pirate:
be interesting to see how long my diff lasts than, ive done countless limiter launchs, no load on the drivetrain. just a simple sidestep and hang on, havnt broke anything....... yet
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
