i got a 96 r33 s2 cat back exhaust manual boost controller (12psi) pod filter not too much mods stock ecu, i was driving home tonight and i went around a corner in 2nd (40kms a hr) give it some stick! then my car sound like a dirty old commodore when i accelerate sounds like its comming from the turbo, engine sounds normal but on idle the turbo sounds soo sick any ideas?
https://www.sau.com.au/forums/topic/363830-r33-s2/
I would also say you might have popped a hose off or an intercooler pipe for that matter.
The next thing you have to ask; is it still making boost? If zero your turbo is blown. If it is still boosting but it sounds rooted, try find that air leak.. If not you might want to do a compression test.
My first car underwent a "rexy conversion" under the same sort of circumstances, was thrashing its guts out and it suddenly sounded awesome! But had no power.. Compression test revealed I had blown the gasket between cyl 3 and 4.
GL
https://www.sau.com.au/forums/topic/363830-r33-s2/#findComment-5805525
i had a similar problem with my 96 s2, it would accelerate fine if i was pussy footing it, but as soon as it was punished the engine basically started so sound like a chainsaw made by holden, ended up being the coilpacks breaking down. and that was after i was told by 3 96 s2 owners that it had happened to them. if u want to get some splitfire coilpacks try cj-motors. he sells them on the internet for $575. brrand new.
https://www.sau.com.au/forums/topic/363830-r33-s2/#findComment-5806578
Need to know more info on the noise. However at a guess it's the same problem 99% of Skylines suffer - missfiring.
15-20 year old coilpacks and some times incorrectly chosen spark plugs will cause miss firing. Especially on a cold night.
https://www.sau.com.au/forums/topic/363830-r33-s2/#findComment-5806630
Err...turbo shouldn't be doing anything on idle?
It could be coilpacks...if one goes on you, your car will drive like a bag of shit and vibrate while accelerating but feel not as bad when cruising and totally fine when backing off accelerator.
https://www.sau.com.au/forums/topic/363830-r33-s2/#findComment-5806760
thanks for the help guys! ended up being my exhaust manifold gasket and a turbo gasket that was stuffed! so its in the exhaust shop atm getting those 2 gaskets done and while he has it apart he is changing the stock front / dump pipe to a 3in.
https://www.sau.com.au/forums/topic/363830-r33-s2/#findComment-5807411
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
