ok, engine is rb25, standard except turbo back exhaust n fmic.
now engine has no top end power, made 111kw which is pathetic...
seems to pull alright until about 5,000 rpm then stuggles to rev the will pull hard from 6 to 7...
ive checked, fuel pressure, vvt, all timing marks line up, exhaust back pressure, comp tested, all 6 are 140... swapped CAS over for shits n giggles...
dont know what else to do, please help :(
https://www.sau.com.au/forums/topic/364042-no-power-please-help/
the stock ECU does not have flat spots on the map on purpose, or by design
the stock ecu is designed for basic engine control, reasonable power and lots of protection
it does, however, have lots of protection built in if you up the boost or make it work harder than it should
then, it resorts to simplistic and retarded mapping and fairly conservative tune settings
so by swapping ecu's youll achieve zero
the tune is hardset, it doesnt forgot or become lazy etc
id say you have a basic issue, a sensor missing or something simple
check the basics
flat spots can exist if you are using the wrong MEC chip for your engine type
that is, if you have a RB25 and youve picked up any old R33 ECU and hope it works
i dont know why or how but it matters
i had a R33 ECU remap on my GTST and it was the wrong MEC chip and it run like ass
like absolute ASS. why i have no idea, the remapper said "WRONG MEC CHIP TYPE"
so whatever that means
so if your setup is part of an engine swap / ecu swap etc, check this
ive been to a tuner and they said to check the timing marks which i have done... i have to which i think are unrelated, i get boost creep which the tuner has put down to the wastegate not flowing enough, as the boost starts rising it looses power... would have thought the power would rise as the boost does...
as i said, the stock ecu has lots of protection built in
if boost is rising, something is wrong
if its a bog stock GTST with an exhaust boost should be 7psi bang on
if its spiking and going past 10psi ish then it will hit the stock ecu protection and youll loose all the power
ive put the 25 into a r32, boost holds at 7psi, then past 5000rpm creeps to 15... ive never heard of the MEC chip?? i did buy a random rb25 ecu tho... i can run my profect b to 14psi but as it gets to 5000rpm power drops off still...
well youve been told whats wrong, fix the boost control
its way too much for the standard ECU
it has aggressive proteciotn built in for stupidheads that try things like that
so either
turn the boost down
replace the stock ecu with a stand alone
or remap the standard ecu
fix the exhaust
something is wrong, the std turbo should never creep like that
if the actuator is disconnected, its unlimited boost mode and the wastegate will never open
so never run with disconnected actuator
thats the thing, i get boost creep so i cant... i get boost creep even with the actuator disconnected and the flap open...
You are getting boost creep due to poor boost control.
Nothing more, nothing less. The “tuner” claiming the wastegate ‘doesn’t flow enough’ is simply a case of he has no idea what he is talking about.
Every single other GTS-t out there doesn’t spike to 15psi – so why should yours?
I place my bets on your dump pipe. You said it was a turbo back exhaust, I bet it's a cheap/copy dump and the wastegate flap is getting stuck and only opening 50% or so, causing these issues.
The stock wastegate flows plenty - It sounds like it's being hindered.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
