  • Replies 221
Posted Images
Just first reminder for those entering..(first of prob many)
Competitors must wear non-flammable clothing extended from ankles to neck to wrists. Nylon clothing is not
permitted. Shoes must be closed toe.
this will be strictly enforced. and we will be checking during scrutinizing.
Driver and passenger have to wear long sleeves and pants and be non flammable..turn up in shorts and tshirt and you will be on a mission to kmart prior to racing!!!
Please take note of this people!
You must (and any passenger) wear pants down to your ankles, long sleeve shirt / jumper (with the sleeves down at all times)! We will be policing.
SAU VIC Motorsport long sleeves 'T will be available for purchase on the day
Link
You must (and any passenger) wear pants down to your ankles, long sleeve shirt / jumper (with the sleeves down at all times)! This is a requirement of the insurer. If we wish to continue running these events, we must compile and police to their requirements.
Link
What sizings are left in the shirts?? (because you know people are going to ask :P)
Entry forms emailed and payment transfered.
Just realised that my AASA is out of date. Can I get a new one on the day (forms filled out prior), or do I have to send away for renewal? If so, does anyone know how long this normally takes? eg. Will I have it by the 5th?
See you all soon.
Brendan.
HOLY SHIIIIT! I'm totally shotgunning passenger :).
I also shotgunned a passenger ride the other night for this coming DECA. I shall be whoring myself out for passenger rides in the arvo in everyone's cars. Yay :D Looking forward to more DECA shenanigans.
Disclaimer: no I'm not entering the Cube...ever!
Edited by llama_au
i left my AASA bit blank as i need a new one as well. you can get it up there on the day im sure
You can get the AASA on the day, though it would be preferred if you have them organised prior (especially since Bec will be supervising me at my first run of the sign in :nyaanyaa: ) - just make sure you tell them you need it for an event on the 4th June, and if they cant send the card out by then have them provide your licence details via email and bring that.
Entry forms emailed and payment transfered. Just realised that my AASA is out of date. Can I get a new one on the day (forms filled out prior), or do I have to send away for renewal? If so, does anyone know how long this normally takes? eg. Will I have it by the 5th?See you all soon.Brendan.
If you do it prior, as I mentioned above make sure you tell them you need it for an event on the 4th June, if they can't have the physical card to you at least ask for an email with your licence details on it. We need the number and expiry etc for the paperwork on the day.
You can also apply on the day for an AASA licence if worst case, just make sure you have correct cash for it as we have limited change...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
