Try www.Injectorsonline.com they are in Melbourne and can do their modified and flowmatched 1000cc 3/4 length 14mm Bosch/ID's for around $700. They idle perfectly in my car. Otherwise they do the usual Deka 610's pretty cheap too. Ask them if they will price match, you may be surprised.
  • Replies 205
Pipster. There is some ls injectors on eBay and it says falcon needs different plugs. Why can't all companies just use the same plugs :/
yeah i think they use their own plugs, bit annoying
just buy chef_stagea's injectors, they come with a loom to suit them and all the spacers needed etc.
check the stagea classifieds
What's wrong with the HKS ones? Direct fit for your motor at about $450 + postage.
wow that cheap, probably the best way to go
try and get something with 4 holes too, better spray pattern for better fuel consumption and i think you get a bit more power
Damn that's cheap. Not sure how big there are but if you need something bigger, 600 cc from Deatschwerks are only 550 US atm, and the exchange rate is pretty good... I am using these:
www.deatschwerks.com/skyline/skyline-1998-2002
PS they are a direct fit, and include postage IIRC
Edited by DaveB
ok kewl, im getting an atr43ss-1 $1480 delived with oil line :D just hopeing the wastegate actuator isnt too high of a pressure.
let us know how it goes, thats what i was thinking of replacing mine with
or a g3
Hi
I have 6 850cc power enterprise injectors here if your game they were to big for what i wanted i used 550cc instead. I also have a Z32 afm if you are interested.
If you want the full story on these parts just PM me.
Lmao. How was traction at 250kw??
fine, it never broke traction. i do have 245's on it, and i think having an auto helps with traction. i cant just drop the clutch and get instant power. even now in the wet it's hard to get it to break traction, got to be turning and get weight off the driven wheel to get it into a slide, but the 4WD straightens it out almost straight away anyway.
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
