  • Replies 42
ECU detects speed limit reached, cuts fuel, car slows down below limiter, fuel re-engages, car speeds up again and repeat.
Therefore the needle will just bounce back and forth off 180km/h.
I thought on most models the ECU backed of the timing to the point where the car simply can't accelerate anymore? Wouldn't on/off fuel risk damage?
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825490
Pretty sure it is fuel cut. Most cars use a fuel cut on speed limit and on rev limiter. It doesn't damage the engine since there is no fuel to burn, therefore no combustion.
Ignition cut is what the BeeR Revlimiter and antilag uses.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825551
I can tell you from experience at track days that it is a very smooth process in practise. The car just stops accelerating and speedo needle climbs no further ( though on my car needle is off end of scale- guessing about 190kph position - speedo error!).
It is different in lower gears though and on the skid pan in 2nd gear it will bounce off the fuel cut rhythmically if you let it.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825583
The electronic throttle closes as if you backed off to hold that speed. Very accurate too, every pass I did at Calder was 171kph by their measurement.
The maximum throttle opening I have seen with the Stagea is 86%, at launch it bogs down because the throttle is limited to 36%.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825641
Wouldn't it be a noticeable "bounce" off the limiter if it's a fuel cut? One GTST i've been in (private property), the limiter just stopped the car accelerating quite smoothly, rather than the usual "derp, a, derp, a, derp, a"
How does it keep the limiter "smooth"?
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825907
Progressive fuel cut maybe? Not 100% on that one. I have hit the stock limiter in the R33 back in the day and yeah it is very smooth.
In the Vipec you can choose what type of cut you want. You can also set up a 2 way setup for a soft cut and a hard cut so my actual limiter in the car is very smooth now, similar to what the speed limiter was.
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5825960
That's interesting. Might need to do a bit more research. That's what I meant, the speed limiter is different to the rev limiter, where the engine reaches say 7000rpm, then just cuts out and effectively starts again. While the speed limiter is more like lifting your foot off the throttle, yet it's cable operated.
You'd think a fuel cut to sound/act like the rev limiter (lol, it is a fuel cut), yet the speed limiter is more of a wall rather than an on/off/on/off. The car doesn't have any means of restricting air intake, so it's either fuel or ignition adjustment to slow things down? But removing fuel partially would make it run lean?
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5826085
So annoying this feature. Japs make such fast cars then limit it... My speedometre stops at 180km/ph.
On one track day at Eastern Creek, was over taken by 2 cars down the main straight cause I was just bouncing on 180.
I didnt feel any cut off jerks or the feeling of slowing down, the car just wasnt going any faster.
So yeah, back to what T4NK was saying. How do we fix this?
And when the limiter is cleared, how would we replace the speedometre on the dash so it reads above 180 (like from an US market G35) and also reconfigure the dials so the needle is acurate with the speed of the car.
Edited by Bourbon Boy
https://www.sau.com.au/forums/topic/365101-speed-limiters/#findComment-5827990
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
