1991 R32 GTR Australian Limited Edition Model
100 cars were brought in to homologate race cars for Bathurst.
65-85 were sold privately and the rest were raced.
Priced at $ 105,000 in 1991
Genuine Godzilla.
Australian spec cars not identical to Japanese spec
Model 40ZKBNR32RX
Chassis 016042
Build date 5/91
Confirmed in Nissan Tech Sheet T 434 1.8.91
Delivered by Alf Barbagallo Nissan in Perth Western Australia
Original manual and "how to drive your GTR" in leather compendium come with car.
I have owned the the car for 5 yrs having bought it after an idler pulley failure at 245,000km.
New RB26dett engine (3000km ago), clutch, brake rotors, pads and master cylinder have been fitted.
It is in excellent condition, drives very well, only needing some cosmetic improvements to be perfect.
I have many spares that could be part of a deal but will only sell the spares if the car is sold.
Spares include a complete engine needing head reconditioning. Short engine. 4WD R32 GTR gearbox. Nismo Group A spec RS 581 turbos. 700cc Sard injectors, Tomei cams. Aftermarket manifolds.
This is a rare, collectible car that will appreciate in the future but can be enjoyed and driven regularly now.
Also listed on Carsales.com.au and Unique Cars June Edition.
I would like a quick sale so asking $ 37,500
Frank 0429681100 ( please ring WA time )
https://www.sau.com.au/forums/topic/365202-aussie-delivered-r32-gtr-1991/
The first owner painted the car black after hitting a cat very early in the piece.
Apparently Black was a $5000 option.
I think all the Australian cars are a light grey under the bonnet.
The paint code KJ1G on the vehicle plate is for Jet Silver Metallic, not black that the car is painted. May explain the mis-matched engine bay colour.
Good luck with the sale.
Certainly not all silver under the bonnet, check the immaculate one for sale on the forum is still black under the bonnet. This is a great chance for someone to restore this thing and get a bargain.. Needing a full respray after hitting a cat though... Would be blown away if the front lip needed replacing..
First owner was apparently a well off dentist with a country practice in Bunbury.
I assume he actually wanted a black one in the first place.
Perhaps out of respect to the cat??
Under the bonnet certainly doesn't look as though its been changed.
That's my old car !
Can't believe it's been 5yrs since I had it up here on the forums for sale.
I still miss this one :(
The original motor clicked over 240,000kms before the idler pulley seized as the car was being parked. So valves will be bent in the old motors head. Worth grabbing the old engine so as to have matching numbers.
The dodgy on the paint code may have something to do with the owner previous to me having a this car and a silver one. The silver one had a black paint code from memory.
Is the new motor a reconditioned one Frank?
Someone buying this car will certainly be getting a nice GTR. Having owned a few , this one is my favorite. :D
Hi
Glad to hear you are still around. Time flies. I think its 5 yrs next month.
Certainly is your old car.
There was some head damage but basically it was quicker to get another motor at the time.
Planned to rebuild the old one with all the good bits but one of those things that hasn't happened.
Certainly have all the bits to build a really good one.
I would imagine whoever bought the GTR would want at least the old block.
The new motor is a R33 GTR. RB26dett
Rings, bearings and turbos overhauled. Goes very well.
Getting almost the same hp you were getting with just a little extra boost and a fairly standard motor.
GTR still goes well. Nice and tight. Scary fast.
Got in touch with the original owner's son who told me it was his mother's car mainly.
She had it painted black.
Like to sell to someone who will appreciate her.
Frank
That's my old car !
Hi,
Do you still have your car?
Perhaps the cars could catch up?
Does anyone want to give me an offer???
:action-smiley-069:
This car probably sat next to mine in the dealership.
Free bump, great price.
  • Like 1
  • 5 years later...
This car is still for sale.
Asking $35,000 or near offer.
These are now quite rare. Cheap price due to r33 rb26dett engine and black paint.
Good value
Frank
  • Like 2
  • 1 month later...
  • 4 weeks later...
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
