Yes poor me!
On another note!
Anyone interested in a R34 GTR cooler? I originally bought it off SLED when he had his 34.
the cooler has done 360+rwkw so it flows well and does a good job at cooling.
also because its not sprayed black you can see it better than a STD R32&33 core.
PM me
  • Replies 3.6k
Posted Images
i'd love the car to have a lumpier idle, but i think with possibly being a home owner in 4 weeks time is going to put a serious halt on getting cams.
Looks like I'll be picking up the keys for mine in 4 weeks. I can see it putting a serious curtailing on my mod plans for the near future :(
To any of the Northy usual suspects, I am going to be fitting some new toys to the V35 today if anyone is keen to come watch/help/drink.
What are you fitting? Might be keen if its interesting.
Well I dont wanna jinx it just yet but i might be handing over some keys next week!
so what's next Damo.........EVO hairdresser's special or maybe a Taxi ???
Stop being a girlie-man.......you know you want to :nyaanyaa:
Might see you up there Brad..............or if you're down south, you can help me hook up power to the new shed :whistling:
If i was going to buy another daily import, id seriously consider an Evo 6.5 TME.
this girl doesn't like pink skylines but i think we could forgive her
http://www.facebook.com/people/Belle-Ranse/1165256214
i would swap/buy a Evo in a heart beat all the bad press lately :/ but then i would miss the line
Considering she likes Justin Bieber...I am gonna say she is a younger then 18...or seriously messed up, and her profile is private :down:
-7s are the same as 34 n1s
33 n1s are laggy pos
If you're happy with 300kw then you want -9s as they are basically an updated -7, they make more power but have extremely similar spool times. They are however slightly more expensive. -5s need something to help wake them up. Lots of boost is ideal but obviously not for a standard motor. I use poncams. E85 would help massively too. -5s+E85 would be the perfect street setup on a gtr IMO.
-7s or -9s are the turbos you want.
Exactly.
-7 are R34 N1
-9 are HKS GT-SS (No difference except HKS run a better actuator)
-5 are comparable to HKS 2530 (2530 slightly different)
-10 are HKS GT-RS.
If your looking at replacing your turbos -9/GT-SS are the way to go. I haven't had mine tuned yet, but going by others results full boost by alittle over 3k and will flow enough for 330kw. -7 are still decent but you will need to push them to make over 300kw. -5 are the 330-400kw turbo and really need 18psi + to be efficient. If you want 300 and below why buy -5? Alright with the -5 you've got more head room for more power but why? Why do you need 350kw to go 60kp/h?
But Dohmar don't you have the standard ceramics rebuilt to N1 specs? That's probably whats robbing your power setup and probably a really safe tune. I mean Weezy made 270rwkw with stock turbos at 1 bar with standard afm, injectors and a pfc.
its sad you looked at that :blink: of course she is 18 :ermm:
1. I am bored
2. I am lonely
3. I was curious
4. I am seriously messed up
choose any 4
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
