  • Replies 3.6k
Posted Images
Lol. People actually care about the cost of what they drink?
If you're making that argument, you should stick to Carlton Draught for credibility.
CD's are my favorite cheap drink.
Better then drinking VB, WestEnd, XXXX etc
I even have my bar fridge stocked with a carton of CD's tinnies for when people come around :D
Don't touch my good stuff!
booze in oz cost to farking much, pretty bad when you can buy imported just as cheap as local grog.
JACK =YACK, its like liquid stupid .. I know better then to drink it but after a case of beer a jack and coke goes down easy... comes up after the 4th one..hahah... lets just say I know a cat box has another use besides cat poo.... and not go any further I think you can get the hint..lol
speaking of that I still have the photos of kadina a few years back floating around ,,, that was a good time , but think luke slept the whole next day in the back of his car.lol
Edited by Carbon 34
Anyone else here keen on Singapore F1 in Sept?
Theres 5 of us heading over on wed 19th sept and coming back on the 25th (6nights)
Flights will be with Emerites and go via melb on the way there but return is direct. $950 return
Accomodation we are looking at staying at the http://www.millenniumhotels.com.sg/grandcopthornewaterfront/index.html and is $1070 for the 6night per person
Straight away i would need a $165 deposit per person just to secure the room. Flights will need to be paid in september.
Picked myself up one of these for a treat - it's nice! :yes:
Yeah it's not bad ... but I prefer Johnny Black with some French oak shavings in it for a couple of weeks ....
I picked up a bottle of double black for $47 from 1st Choice - it was cheaper than normal Johnny Black!
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
