Hi all,
I have an r32 gts and it makes a sound coming from around the bell housing.
It makes a noise similar to the sound of a spun bearing.
The noise only occurs when the clutch is out and stops when the clutch is pushed in.
Wondering what is causing the noise The Thrust bearing or the gearbox input shaft bearing?
Hi all,
Input shaft bearing. When the clutch is disengaged, the input shaft stops turning, stopping the noise. Release the clutch, shaft turns, noise returns.
This is all normally true diagnosis^
However, some thrust bearings in Skylines produce a noise even in neutral with the clutch out, because they rub up against the pressure plate in the resting position. Try putting a little bit of pressure of the clutch pedal, i.e. don't push it in, just push the pedal until it gets to the point where you have to start trying. If the noise goes away, it'll be thrust bearing. If it's still there, most likely gearbox rollover noise which can be an input shaft or the gears simply meshing incorrectly (happens with age and wear).
It makes the noise in neutral and when driving (can't hear it much cause of loud exhaust :) )
birds, ill check with the clutch only slightly pushed in like you said. I hope it is the thrust bearing cause i really can't be bothered replacing the isb since I am planning on putting a turbo motor and box in within the next year or so.
True
And being a hydraulic clutch, there'll always be contact, as the slave cylinder "self adjusts". Another method is to hoist the car and pull the clutch fork (depending on whether it's a push or pull type clutch) away from the diaphgram spring, taking the thrust bearing with it...
  • 4 months later...
  • 5 months later...
I also have a similar noise in my GTR. I only got it about a week or two ago, so still learning as much as i can about it.
My one makes a noise while I am in netural, once i press the clutch in. It goes quiet. Take it out, the "whirring" "whine" noise comes back.
A friend said its a thrust bearing, but from reading the replies in this thread i am confused and not sure.
Anybody know if it will do my car any harm?
General consensus says you need to take out the gearbox to fix it, so i may as well wait till i need a clutch as long as it isn't damaging anything by waiting.
the whirring is the thrust bearing, perfectly normal. i recently replaced my clutch and thrust bearing and the whirring noise is there just as it was before, i also think its got something to do with my r34 and your 33 gtr being pull type clutches im sure someone else can either confirm or correct me on this.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
