Hello from Canada :)
It looks like quite a bit of Canadians are invading as R32 Skylines are getting nearer and nearer for import.
So I was all over the GTR, but sticking to a tight budget isn't what I do best, and the nice quality GTRs are going up in price, so I've looked at other look nice, all year cars :D
Now it's come down to two cars (if I import) a 1989-1990 180SX or a 1989-1990 R32 GTST.
Now I already know what the 180SX can do in terms of power with the CA18 and what it will take to obtain my goals.
Now the GTST and the 180SX weigh almost the same. My goals basically is a low 12 second drag car, a street car, and an auto x car (all three MUST be there) now for the 180SX this required a Disco Potato Turbo (don't know if you've even heard of this turbo, it's like a crazy Hybrid T28) which with proper tuning, and parts, can make 330-350wrhp, and it has a fast spool up, which means low lag :)
Now I need to learn a few things about the GTST
For chassis/suspension which parts are interchangable from GTR aftermarket parts? But since it does share the chassis with the GTR (well kinda) it probally doesn't suffer from really limited suspension travel like the 180SX, and comming stock with nicer brakes is cool too.
On stock internals (cept cams) and with proper tuning (on 91 octane canadian gas) how much power should I expect to make with new piping, turbo fmic etc?
And what's the weight ratio on the GTST? Thanks ;)
PS is the Type M worth to get, HICAS good/bad? What else does the Type M include?
Welcome to the wonderful world of Canada's 15 year import law, unlike you Aussie's we don't have any exceptions.
15 years to the month and year. I don't plan to get it til next year, but I'd like to set a goal up soon :)
So no SR20DET powered 180SX for me :(
Have heard of the Disco potato. It's listed in the Garret catalog (GT28RS).
1. Get the Skyline.
2. Get the GTS-t Type-M with the mods already on it out of Japan (at LEAST exhaust and maybe FMIC)
3. HICAS is ok, you might find it makes the handling slightly unpredictable at autocross.
4. 91 Octane canadian is about 95 or so octane in Australia? What are your options for fuel? Most of us here run 98 octane all the time. 100 in Japan.
Keep in mind that a 15 year old car like the GTS-t is going to be kinda rough coming from Japan and budget for that. Parts are going to be costly for you as well. At least with the 180sx there was the 240sx model locally and the SR20/CA18 scene is pretty well established over there.
But the skyline will give you the unique factor.
91 octane is probally the best gas we can get, unless if we got ethenol blend (94 octane) here in my city (but only two stations in the city have it) Although the city isn't big (700,000 ppl)
I'm not too sure what the gas system is in Australia...so I can't really compare.
Yea we got the 240SX here, but no one in my city has a SR20DET or a CA18DET, however we did just get our FIRST KA24E-T (that's right the old school SOHC KA) it was finished sometime this week.
However we have had a R33 RB26DETT powered 240Z since last summer :( It's making about about 350-400 hp, I can't remember exactly (those are crank numbers)
So in fact, our city acctually has more experience with RB26DETTs than we do with CAs or SRs
I agree the skyline will give me the unique factor and it may for handling edge out the 180, due to a more sofisiticated suspension, and braking system. But in terms of reliablity...that might be hard...which is why I'm here asking questions :)
At least with the 180SX, if anything breaks parts are easy to find, and the CA18DET is similar enough to the CA18DE found in the 88 pulsar that people can work on it. Plus the fact I can find a block heater is good.
A Block Heater FYI is an electrical element that heats up the block keeping the fluids above melting temperature for the winter (you plug it into a electrical outlet) And with -50C winters, we need it :D Although our summers get to like +40C
But yea, again letting you know, this car will be driven in snow, rain, hail, soot, and in the heat :)
howdy canuck! I was just in Canada in Feb, Vancouver and Whistler. I must say that Australia has flashier cars and Canada has a lot more practical cars, SUV"s etc. Everything has 4WD! BMW 3 series, everything seemed to have a 4WD variant. But being over there in Winter i can see why the big 4WD's are so popular, u bloody need them.
I didn't see that many 240sx's in Vancouver. A few here and there. prob a more S14's then 13's.
anyways, great country u've got there. And good luck with the car. Oh, and get a R32 GTR, u know u want to! :P
Us Canadians are taking over the place :(
They shouldn't fear the Americans, we're the ones that are invading :)
But I still need to know more about the RB20, Weight Reduction on the HCR32 (which there are probally lots of places) hopefully HICAS weighs like 30Kilos or something, suspension etc :(
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
