So it says passengers have to pay a small fee, (which is $0), and they can jump in on passenger runs, how many passenger runs will their be??
Also how do you pay $0?
And do you just pay it on the day?
:D
  • Replies 264
yes im pumped!
here is the current forecast:
Saturday 17 December
Cloudy. The chance of showers. Winds east to northeasterly averaging 10 to 20 km/h. Overnight temperatures falling to between 7 and 11 with daytime temperatures reaching between 19 and 25.
im pumped to see what 135KW at 3000 RPM can do on a race track!
:D
I will be there to collect the $0 :D
The whole day is passenger runs
Leaving for G town soon, see you all tomorrow!
Final prep all done! woohoo!
New front bar - check
New racing harness - check
New LCD guage - check
New Haltech ECU + tune - check
Complete overhaul on engine, new balancer, new IN cam gear, new timing belt and bearings, ALL new racing lubricants - check!
New surge tank - check
MAXED out credit card - check
Time for some dinner and sleep! see you all in the morning! Bring on the sunshine!
Wow that's a lot!
Good work for getting all that ready in time!
