  • Replies 165
Yep,
Craig sure is helpful - offered great service and very professional...
... And the work he did on the car was pretty good too...
Jokes aside, turbo off for a rebuild. Will update with the rebuild quality and what it performs like when installed for future members.
Hoping to do the LHS rocker cover gasket and a few other things while its out.
Cheers,
Sean
So just attempting to replace the LHS cam cover gasket.
How the F&$K do you get the rear right bolt off? I can't get the soft water line off and the sheathing on the loom keeps snapping.
For anyone new - engine out everytime. NOT only quicker but less grazed knuckles....
Not forgetting the fact I'm gonna forget where all the bolts and plugs go :(
Sean
Sean
LOL!
Sean
WTF?!?!?!?!?!?!
Did you own a 300ZX prior to your M35?? :P
Actually I did...
I meant engine out for turbo replacement and ust do everything else while it's there...
I've given up for the day. Cam cover still on by one f@&$ing bolt and now I'm contemplating pulling the engine. I have no time or patience for V6 turbo's ahaha..
So no tricks for that last bolt near the coolant hardpipe?
Lol.
I thought you were complaining about the gasket falling out but you havent made it that far yet. :)
I use a 1/4 socket set only, for the rear ones I use the uni joint and a few extensions I think.
I know - I fail at being a man. A single bolt made me almost set fire to the car today.
I'll give it another crack on the weekend when I'm not working and hopefully get it done. Probably get a uni though. Doesn't help I lost my 1/4 drive socket :(
On the plus side I saw I could just use the same upper plenum gasket instead of having to order.
Do you guys torque up the bolts or just use some thread lock?
Lol.
Yup, 1/4 socket, uni joint and an extension
Those gaskets are good for re-use plenty of times.
Just do the bolts up tight.
One note however, the bolts will snap before the cam cover is pulled down tight >_<
One note however, the bolts will snap before the cam cover is pulled down tight pinch.gif
Whoa! So what are you saying? Should one buy new/higher strength bolts or what?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
