93 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Just thought I'd throw up a poll to see how everyone shifts whether it be during everyday cruising or on the track. I personally just use my ears and if I'm really going for it then ears + as soon as I JUST feel it stop pulling as hard is when I shift, that's generally anyway not always. What do you think the best sense is or whether technology/equipment is far better?
Edited by Borci88
https://www.sau.com.au/forums/topic/366803-how-do-you-sense-your-shift-points/
everyday driving, it's usually around 2500 to 3000rpm, but it's more just done instinctively as what provides enough acceleration while still keeping both the rpm and the throttle percentage low to get good fuel economy.
in performance mode though, i use the redline as my guide. the car pulls hard to redline so there's no point changing earlier. if you go buy the "it's feeling like it's not pulling as hard" theory then you also need to pay close attention to whether it pulls as hard once you change gears, because sometimes even though the acceleration rate is slowing down, the acceleration is still faster than in the next gear.
a mix of sound, timing and the feel of the car. It's not 100% though. Hit limiter jumping on a hwy the other day.
SRs tend to drop off a bit before redline so i tend to change a bit earlier, if going hard.
general traffic 3500. then it varies depending on hills, slow cars, and how fast you wanna get around that slow car.
on the track. redline, the gearing i find is beautifully set in these cars, snapping the next gear at redline seems to pull the hardest into the next one and so on. (standard R33)
i find it doesnt really stop pulling before redline, if so only ever so slightly. But those few extra revs will get you higher into the peak rev range for the next gear.
Too many factors... In my Pootrol, I change up at about 1500-4000, depending on how much noise I want to make, (speed is not a factor, cause it is leaisurely no matter what revs..) In the GTR, between 2000-8000, depending on a lot of factors
I plot the torque curve, then calculate the tractive effort at 50RPM increments in each gear throughout the entire rev range. I then calculate the section of the curve that gives the biggest area under the curve for each gear change, which gives me the shift point for each gear. Then I program my shift light for the optimum gear change point for each gear
Not really. Actually the rev limiter does a pretty good job of telling me when to change :thumbsup:
In the Rex somewhere around 6500. In the Hoonda, it's about 8500 (cutout at 8700) and in the Pathfinder about 2500-3000
Daily driving its the seat of the pants. It will depend on road gradient, the speed limit, traffic speed, etc.
On the track, in the lower gears I'll do it by feel/sound. In the higher gears I'll watch the tacho when I can hear the engine getting close to the cutout.
thought about this on the next drive after posting....traffic sucks....no one does the speed limit...usually around 2000 as granny driving seems to be the only way most people drive these days ...:glare:
but in general keeping the boost gauge on the vacuum side of things makes for better fuel economy. so i make that work as best possible.
I tell usually by sound at lower gears and tacho at higher gears, and in practice (on the street) I always short shift before 5000rpm. I probably exceed 5000rpm about once per week at most (daily driving). Can't remember the last time I went past 6000rpm, on the street it just isn't required (theoretically it would be required for a drag race).
On the street in 1st and 2nd gear with any sort of corner I short shift to get into the next gear so I can ride the torque wave through and out of the corner. This means precise throttle modulation is less of a factor and it saves a gear change and means less wear(2nd has more power but can't usually put it all to the ground). Adding bumps into the equation in Sydney just makes it even more relevant.
Just cruising I change at the point the revs start at 2000rpm -2200rpm in the next gear....or what feels right.
Edited by simpletool
Only ever play close attention to the tacho when on WOT
This
Cruising around I just change gears. Not by noise, not exactly by feel... I just throw it to the next cog. Apparently I'm known to shift below 2000 rpm like this, especially in my Subie :laugh:
shift for best economy most of the time , 2500rpm so it sounds like booooar boooarrr :huh:
after a while this can become boring and opportunities arise for some booarrrr rrr ashhhhhhhhhh du dudududu, and repeat lol :no::yes:
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
