SHORT NOTICE!! Group buy EXEDY CLUTCH KITS!!!
:D:):( :( :(
DUE TO UNFORSEEN CIRCUMSTANCES, I AM UNABLE TO SUPPLY THE CLUTCHES FOR YOU GUYS.. :(
DUE TO THE RECENT TAKEOVER OF THE COMPANY.. ORDERS FROM SUPPLIERS HAVE BEEN MADE STICTLY LIMITED
I DEEPLY APOLOGISE TO ALL THAT REPLIED.. COS IT LOOKED LIKE WE WOULD HAVE HAD ABOUT 10 PPL IN THE GROUP BUY.. :(
IM VERY SORRY THAT I WASTED YOUR TIME.. *SOBS*
ONLY FOUND OUT THIS INFORMATION YESTERDAY.
ONCE AGAIN I DO APOLOGISE FOR ANY INCONVINIENCE
KYLIE
*WAITS TO BE SLAPPED*
:slap:
TTFN
  • Replies 51
Just bought a rb26 to go into my r32gts-t I was wondering if I can drill some more holes in my rb20 lightend flywheel to suit a rb25 clutch whilst still using the rb20 g/box, until I save up the cash for a rb25g/box? Will it fit and if so could you please pm me a price on an rb25 button clutch. Thanks.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
