www.durafix.com
Discuss!
p.s. I barely got half way through the vid and I skipped ahead to eBay and bought a pack of 20!
p.p.s. if anyone is concerned about strength, there's another video when a guy has welded 10mm plates of ally together at right angles, smacks one side with a hammer and the ally begins to bend before the weld fails!
p.p.p.s. http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=270768970566&ssPageName=STRK:MEWNX:IT#ht_3105wt_1139
https://www.sau.com.au/forums/topic/368666-durafix-easy-weld/
Looks handy to have around, but its around $50 for 40 rods and you need an oxy.
i'd love to try it for rim repairs though
See that eBay link? $11 US for approx 10 rods... Looks like one does a fair bit too...
You don't need an oxy set-up, just a butane torch...
Pretty fkn awsome if it holds up as well as it looks...
Ha ha... I wanna see someone 'solder' up a cooler pipe work set up-
I've bought some for the sole purpose to re-doing my intercooler piping and making an airbox, so I'll update in this thread how I go!
Edited by StealthX
this stuff has been around for yrs i saw a display at a car show over 20 yrs ago i was pretty impressed then . ive never used it but i can see it would be handy to have a few rods in the workshop.
  • 3 months later...
I used this stuff to make up an intake for my car. Turned out OK, considering I have no experience with welding etc.
I used a LPG gas bottle from my bar-b-q, with an appropiate nozzle, to heat up the material. One thing to remember, if you are making something with a few separate parts (like I did), when you heat it up again to stick the new bit on, there's a big chance the original "weld" will start to run. To help with this problem I bought a block of modelling clay and pushed some around the first bit/s to act like a heat sink.
anyone know if they have something similar for steel?
i've got a stick welder and we're trying to modify a pocket bike exhaust onto a motorised push bike (using the band expander)
the cheap chinese steel is so thin that its got a few holes in it
just want something solder like that will work like this does
They usually have a stand at farm machinery days and will weld up any alloy part you bring in to get done. They are very good at it and make it look very easy. I've tried it in different things and it works OK, but I found that using the normal commercially available alloy brazing flux and 10% mag rods is about the same. This was using a Dillon/Henrob oxy.
Chinese metal for things like your talking about is usually terrible stuff to play with. Its usually recycled tseel with inclusions all through it. And then you say it is an exhaust pipe or some such - double whammy. Nothing like exhaust pipe for dirt and crap in the metal.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
