I can hook you up with an Hdi cooler, but you might want 3" piping on the outlet, yes?
So what's the standard inlet/outlet pipe diameter of the HDI cooler?
So reducer required from standard piping into & out of intercooler. No worries.
I had another question re the HDI model, but might post in a more relevant thread. Cheers.
Reducer comes in the kit Leon.
In fact everything you need comes in the kit.
RE the FCON V Pro - Will it definately offer better performance then the EMU?
No one knows whether it can do speed cut right?
POssibly have a cheap one lined up....but want to make sure i'm not wasting my $$ for another pointless tune!
ALso what's the difference between v3.0 -v3.24?
Edited by ironpaw
Well that's what I'm trying to find out. What can it do better then the Emanage? It obviously has something better to offer then the EMU otherwise why are you holding out for it?
I.e. if Cihan tunes both will there be any difference performance wise?
And no one can confirm whether it can overcome speed cut right?
Just trying to save some $$$ for the future if I ever need it :happy:
Holding out for it?
Scott has his and mine is on the way from the US as I type this (fkn finally!).
Yes, it is better than the eManage. You have to keep in mind that while the Pro-V plugs in like a piggyback, it does not manipulate the ECU's signal. It sends it's own signal to the engine.... but we have already covered this.
Why not just wait and see?
If you want to know if the one you are looking at is suitable, send me the link/description.
Holding out for it?
I'm waiting for the guy to send me a pic of the serial number...cheers
Have you got a VQ25det harness?
Weren't many left when I ordered mine.
EDIT: you need the serial number to be 20,001-30,000 for a 3.2/3.24. v3.3 is 30,001+
There are some that may have been re-flashed by HKS when they provided the service though (they don't any more)
Edited by iamhe77
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
