On Saturday we'll give things a nudge. Jez will get some time to get his head around it, see if we can get a bit more timing in at 4psi which I think we're missing. Pop the high range maf in, make sure that's scaled ok.
I want to run without the spacer, then chuck it in and actually see if it makes a difference. Then I've set a limit for myself that day at 6 psi. So will see what that nets with a safe tune. Have seen 9 psi make 300rwkw, and back it up with a 11.9 quarter on a G35, and still be on the safe side with torque. Wish the bugger would just send me his map!
I only run to 6600, the stock limit. I think you run a but higher yeah, like 7200 or something? I'll get something with the top of 4th and Kms n it.
The soft limit is set at 7300 I think and 7600 cut.
I have the option of selling my turbo and buying another, I'm just not sure if I want to yet. I really want to know what this one feels like with the 0.82 rear, but I could just drop a GTX3076 in there with little response lost and shoot higher. Cihan wouldn't be happy. I guess he thinks I have enough powers already.
Scotty, I'm sure you'd have a buyer for your 25 setup. In my opinion, the only way forward with big numbers is the 3.5 and something like a GT35 range. Simply my thoughts are we don't have the space for a big turbo set up- like the RBs run. I don't think you would gain anything by building a VQ25 bottom end- You'll run a bigger turbo and end up in lag land.
Build a 3.5, and run a good sized turbo on it, you won't need the high boost to make power, and it'll come on quicker.
That just leaves the old gearbox chestnut. Posts I've seen in the states said that the build RE box expires around 500whp. Thats a bit worrying. HOWEVER there is currently a FX35 (awd) being build by a shop that are going to try and put GT35 twins through a build RE. Very conservative estimate being 800hp. I guess there is always manual, but rwd isn't going to be fun, and awd looks like a headache- we'll see what dcdc does!
http://www.levelten.com/LEVEL_10_Infiniti_PTS_Bulletproof_Transmission_p/inf-g1800-9000p.htm
One of my mates is selling a GT3076 on fleabay ATM; shame it's a little small for what you're doing...
http://www.ebay.com.au/itm/221018417418?ssPageName=STRK%3AMESELX%3AIT&_trksid=p3984.m1555.l2649#ht_500wt_922
After a heated discussion with Cihan quite a few turbo options were on the table. We both concluded the GTX3076 is probably the turbo of choice for a comfortable 360kw or so, still with the 1.06 Tial rear. Hope I made the right choice...
The GTX3576 was the other option but I would have to buy a new .82 Tial GT35 rear housing, plus the turbo is more expensive. Cost wise I'm better off sticking with the GT30 rear. (for now. ;))
Think E85, and some real boost in it- you'd be deep into the 400s for sure. Just have to find a turbo to do it- would probably max a GT35 out.
I'm just trying to find some GT35r turbo numbers and sheets. Most big # set ups are twins.
Flying the 3.5 flag! :nyaanyaa:
GT35R if it fits.
lol he's already 1 thou away from hitting the firewall.
i wouldnt think its worth the effort and money for 30 kw more, when chances are he'll get about 20 more with the GTX3076. he'll probably end up doing the head gasket though lol.
as Cihan said. No more it will break
haha
yeh it did. but he ended up selling it. so you might see it around. and if you see it for sale. DONT BUY IT lol. thats all ill say.
tractors pretty good. reason why im talking scott into the 3076, is because im taking the GTX3071r of his.
i think its time i started putting the built sr20 to use.
i personaly think the 2.5 is a fine engine but it depends how much pwoer do you want? you got to look into a capable trans and suporting diffs, theres big bucks i think 350kw is probably the limit for the stags its very usable and not too much i dont think but everyone has their different opinion i spose
I would never say that the 25 isn't a good motor. It's a great bit of kit, but frustrated by the ecu. I wish mine was as strong as it!
It's just my thoughts that Scotty has pretty much got to the end of what's able to be done. Maybe it'll creap over 350 with a 3076, maybe it'll pop. Thing is, with a 3.5, you'll get more power easier, at lower boost levels, with less lag, and still very usable around town. Diffs will be fine. The front diff works in a r35, so we're not going to worry it. Main hold back is the gearbox, which if I was going to do properly, I'd get from the states from the place I mentioned earlier.
It's just my opinion, I might be jaded because I got one!
just like going to a rb30!
... and how exactly would he know this? Where has he seen the power limits of a VQ25det? I certainly haven't seen or read of one popping due to reaching it's limit.
jeez someones getting a little sensetive lol.
he doesnt know this, and yes i havnt read of one pooping after reaching its limits either, but i have also not seen or read about a VQ25DET running over 350kw at the wheels. have you?
and im pretty sure no tuner wants to 'pop' a customers car
The issue as I found out wasn't the motor, it was the turbo. He didn't want to push the compressor any further. If I change up he will be fine to push a bit more out of it.
Although he doesn't think the gearbox will last. lol.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
