Hi and thanks for all who gave me pointers and tips for my rebuild got it started this afternoon and took it for a test drive all went well
temp normal great oil pressure for a change was suppised how well it started up and ran since i had added a couple of things once
again thanks and Jono i took a few of you hints and applied them to my rebuild thanks guys................
  • Replies 59
I have uploaded a few pics of the rebuild
Hi yes i didnt mention it i was going to post everything i had done plus cost etc.
For the boring and honing i went to a couple of engineering shops and told them what i wanted
before i decided on who was going to get my hard earned cash.
Total dollars for machining crack testing enlarging oil galleries etc including crank collar
installation was $1455.00 so made sure everything was done as required which could be
seen when assembling motor when i was double checking with plasigauges on main
and big end bearings.
I have built quite a few motors over the years for drag racing etc.and you have to use
same technique with all high output motors or it will end up as a big bang theory.....lol.
Did you check the tunnel size when torqued down with the new ARP main studs? I didnt see you mention any main tunnel honing in the machining operations or the use of a torque plate for that matter.
No probs good to see your on the ball. It would be a big waste of money if one didnt do the tunnel hone ARP stud kits are not cheap.....
Sam...
Yeh was just checking, as alot of people run aftermarket main studs and dont always get the main tunnel honed to bring the tunnel back to round when it distorts from all the extra clamping force.
Sorry, can you confirm if your honing was done with a torque plate?
Thanks
Justin
Sam...
Hi justin yes i had the block bored 87mm and honed with torque plate got block decked the cylinders chamfered
mains tunnel closed/honed oil holes in crank radioused + crack tested and crank coller fitted ended up taking them
2+ months to do the job for me as they could not do all the machine work themselves.
Thanks
Justin
Thanks for clarifying :)
Can anyone confirm if they have ever NOT used a torque plate when honing, and used ARP head studs, and more importantly, did they have any problems with compression due to not using a torque plate?
At work with our torque plate i tested it,
honing, then measuring, then putting on torque plate then measuring again i got varied results;
Standard bolts barely made any difference
11mm studs up to 3 tenths of a thou distortion
12 mm studs up to 4 tenths of a thou
http://www.skylinesaustralia.com/forums/topic/378823-engine-internals-comp-ratios-general-info/page__pid__6040826#entry6040826
that i wrote up a few days ago which has the formula for working out your comp ratio which is more then grinding x amount off
Think of 8.5:1 as minimum and 9:1 as maximum, speak to your tuner, find out what ratio he is comfortable with, the turbo your running
Um , I'm not going to agree on your dynamic CR ideas but thats going to go a little OT and really deserves another thread .
Cheers A .
The how to work out your dynamic compression ratio isn't my idea but i was just explaining the difference between static CR and dynamic CR as someone mentioned the ITBs affect it which it doesn't. I've no idea what dynamic CR should be recommended but i am looking into it
But if you disagree then maybe you should try your best to correct me
Individual throttle valves play a big part in dynamic compression ratios because it means a engine has a lot of throttle area on a per cylinder basis . With single throttles all cylinders have to breathe through the one and you reach a stage where it can't feed them all enough to get adequate cylinder filling .
If you want an engine to breathe well - read fill its cylinders as best as possible - then individual throttles are the best way to go about it .
Look at it this way , take an 8.5 to 1 static (measured by volumes) compression ratio engine and give it individual throttles . Then take the same engine and fit your typical manufacturers single throttle and plenum type inlet manifold . ITBs give the very lowest restriction throttling because they give the least path of resistance to the atmosphere trying to fight its way into your cylinders .
Dynamic CR is all about how much air the cylinders have in them to compress , therefore if the cylinder is only 80% full its dynamic CR will be lower than if it was 100% full - for any given static compression ratio .
The way to make a less expensive to manufacture engine , ie single throttle one , feel good in part throttle conditions is to raise the static CR . In other words we didn't get as much air in as an ITB system could but what we did get was squeesed into a smaller space so the dynamic CR didn't die in the ass as badly as it could have .
Yes cam profiles play their part and the general rule of thumb is that the larger (longer) the durations are the higher the static CR needs to be in order to not lose low end torque . The reason why long period cams lose low end power is because they keep the valves open too long to allow good air trapping efficiency in the cylinders at lowish revs so the cylinder has less air to work with meaning less to compress .
The thing is that if people wish to do silly things with real long cams then its not the engines fault if it cylinders trapping efficiency is low and the static CR too low to do anything helpfull for them . Any engine is a sum of its parts and if the "system" is designed to all work together to make power over a given range then lifes good .
A .
I think you have volumetric efficacy and dynamic compression ratios mixed up, everything you talked about explains volumetric efficacy
So yeah cams will lower the CR with the intake valve closing when the piston is at BDC or the start of the compression stroke, then if you add boost it will raise the CR (rb30det 8.5:1 static comp intake valve closes at 60° ABDC add 15psi and you will have a dynamic comp of around 13.5:1)
We don't use educated guesses or "rule of thumb" when we machine and build performance motors, so for us to build even better motors that perform the best they can for what they will be used for, we have to understand and use the formulas to prevent something that will cause a problem, i.e over cammed for its purpose.
If you think about it low volumetric efficiency leads to a lower dynamic compression ratios , you have to have something in the cylinders to compress to start with .
The longer the valve (cam) timing gets the harder it is to keep the gasses flowing in the right direction at lower revs . This is obviously why engines are cranky at low revs with big cams , the valves are opened early and closed late in an effort for the engine to fill its cylinders at high revs .
Just on this ITBs tend to reduce some of the camminess (reversion) at low revs and small throttle openings because the throttle plates act as a partial barrier to reversion pulses back from the inlet ports .
To each their own , A .
My Approx final cost for my rebuild $5,500.00 + bits I cant remember
CP Forged 8.5.1 Comp Pistons 87mm
Manley H Beam Rods with ARP bolts etc
Nitto Oil Pump & Crank Coller
ACL Bearings
ARP Main & Head Studs
Genuine Water pump Thermostat & Timing belt kit
Cometec Gasket Set
Greddy style manifold
80mm Throttle Body
All welsh plugs
H/Duty 6 Puk clutch Kit
Gearbox Bearing Kit
New Hoses
MACHINING
Block:
Decked
Bored & Honed
Crank Tunnel honed
Top of Bores Chamfered
Oil holes on Crankshaft Radiused
Crank Coller fitted
Crack tested crankshaft
Head surface ground new seals valves checked and reseated
MY INPUT
Remove all Casting flashing from inside Block
Die grind excess material around head to allow better oil return
Assemble Motor
Match ported intake manifold
Mirror Polished Manifold intake Runners
Modify pipes for manifold & blow off to suit manifold
Fit new Bearings in gearbox
Paint and install…..
Engine started pretty much straight up only had to tweak the acc valve a little and all is
Running fine Normal Temp and the best oil pressure this car has ever had….lol
I also purchased a lot of the parts from America as our dollar was $1.09 over there plus
The prices were much cheaper than in Australia
Once again thanks for every ones input i plan to have it on a tuned on a dyno after I run the engine in. Will have to find someone that can tune it with a emanage blue.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
