Could easily be original.
My old engine only recently came out, had never been apart or out in it's life. Not even a head gasket. I've raced the shit out of it for the last 3 years, someone else did before me, and who knows what it did before that since 1989....
Engine still had bore hone marks. Only thing that killed it was a big end failure..... I did a session of 30+ flat out laps in a Qld summer dicing with Group A cars, without an oil cooler. No doubt in my mind the oil would have been so thin it simply lost it's ability to lube.
  • Replies 209
Yeah maybe, but from what I have seen they would not look this good. I mean they really look as if the hone was just done. I moved the pistons side to side and there was little to no movement. The big end looks good too, so with a gasket kit and arp head studs it should be a nice motor.
You can make it flow more and still keep the air speeds up, like I said I am not just going to make the ports as big as I can. The good head builders here in the states do it all the time. Thats how you make the best power with a usable power band.
I have never seen a motor here with lots of miles and failing rings look so good. Most of the time they are real faint if visable at all. Really though it doesnt matter as I was not planning on reringing it unless the cylynder walls were messes up. No scares or scraps and plenty of hone left. Arps and a oem gasket kit and I think I am golden. The big end looks good too.
Anyone know if a oem gasket kit comes with a waterpump gasket? I have a new pump but no gasket with it.
Edited by Driftnuttz
well everyone was bagging the hell out of the 20 cause you cant get decent power with out spending endless amounts of money but it seems the RB24 isn't as bad as everyone seems to think and not as expensive as well considering people have been able to build these for 5-6k and brings on a turbo quicker than a 25
Fair enough, but a fairer comparison would be a rb20 dyno sheet then the same car with the bottom end swap rather than someone sliding around and kicking the clutch to make smoke.
Smoke isn't a fair indicator of power. :)
No, pretty sure they weren't. People were saying that spending the money in the right places made more sense than rebuilding / forging a motor that is already reliable and can make decent power up to a point.
No one said the 24 was bad, there are a few on here before who have already built them, with threads on results. The point was for the same 5-6K you can have a built 2.5 or 3lt with a lot more drive-ability and potential. Bringing the turbo on quicker is irrelevant...what turbo, what engine? GT40 on a 2lt vs a 2530? Right turbo matched to the right motor for the right job.
got a bit of "fulleh sic uleh" in that video.
What a wanker though.
I could make a commodore smoke like that.
Good luck with your "I'm a special kid" RB20 projects. When your wallets are empty, and you're crying because stock RB25s and RB2530s are lapping you, I'm going ot laugh my ass off.
from what i gathered maybe wrong and talking to people but wouldn't a RB24 bring on a turbo quicker than the 25 if both ran the same turbo? cause of the head isn't that the point of 25 head on a 30 bottom to make it more responsive? cause a 24 for would be forcing a similar amount of exhaust gas out as a 25 but through a smaller port there for increasing the velocity which the exhaust gas comes out...or am i way off?
haha couldn't see that happening as from what i've heard Roy's standard 20 can easily keep up with the "big boys" out on the track so much more a 24 could and i'm doing the 24 as a side project as a bit of fun and doing bolt ons for the standard motor i'm putting in atm and i'm not fussed bout 25's lapping me (if they can) it's all for fun and if you don't have fun with it then what's the point of doing it :thumbsup:
Edited by Forged R32
Yeah realise that but with slight port you could get them up to speed surely...??
Can anyone post up links to 24 builds can't seem to find them my eyes must be painted on lol
and has anyone on here done a rb24 ? Can you post setups and dyno figures and what kind of response driveability?
That is the whole point, porting a head usually decreases velocity and makes it worse down low.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
