Godspeed - thanks for checking out my website. Im hoping clients will check out both sides, but I wanted to split it in two as I tend to shoot more indian weddings.
But otherwise design aspect is all fine with the website?
  • Replies 161
Posted Images
Quick shoot of my mates 32. Used a portable camping fluro light to light it up, far better then iPhone 4 light I was using before! Need to make something up that'll cover the excess light, might do that next week if I remember/cbf.
What camera settings did you use? wouldn't mind trying this but have nfi where to start.
yesterdays effort...
been thinking about a micro 4/3 camera with a real fisheye lens pretty much just to get higher quality versions of shots like these. not sure if its a wise move getting into debt for such a stupid reason tho, lol.
specially when i consider the fact that there is not a lot of adelaide left for me to explore, haha. i needs a bigger city, rofl!
Edited by Jay019
Just off the top my head, I used a 50 second exposure and f7.0. Can't remember the focal lenth, but I'll get the Exif data and post it up when I get home. Used a 17-85mm lens too.
Matt's probably the best person to talk to when it comes to light painting though!
And like Sidd said, you need something to hold the shutter down for long periods of time. I've got a external shutter button for these things, cos me $45 from memory.
jay - great effort man.. So how exactly are you doing those shots? Must have missed your previous post. Wait I think I read you got it on pole???
cheers dude. i should take a photo of the setup, but yeah the gopro is mounted on the end of a monopod. its a compact pod so only has a reach of 145cm. it does fit in my bag tho, folding up to just 39cm. i would love a stomping 192mm gitzo, but dont have a spare couple hundred bucks laying around, lol. need to work out a better ball head for this one, atm im just using one stolen off a cheap fold up table tripod form the 90's.
Edited by Jay019
Well, splitting them would also have the added benefit of those who *are*, say, very anglo, looking at your site and being able to straight away click on the Western side, if that's all they're interested in – instead of clicking into a gallery which contains both, and therefore contains pictures they're simply not interested in. And vice versa. I think it's a very good idea.
Yeah. I do reckon it looks great. The look and feel of the website has a nice crisp feel to it with no overbearing details, which says something about the photographer and the product that people can expect. Navigation and load speed are fine too, even on my 1990-spec Dell work laptop. :)
Now that's starting to freak me out! Great shot. Can you try a bit more photoshopping to up the contrast further and emphasise the depth (or height) of the drop?
@ josh23457 Here you go man
Gorgeous motor - I'm not the keenest Porsche fan but the 993 GT2 is definitely one of my favourites, and this would cost a bomb to buy.
cheers man, i want to take photos that make people physicaly ill. being scarred of heights myself i start getting headspins looking at some of the shots i have taken, haha.
i could try upping contrast, but the source was from a gopro which arent really made for stills. been considering a micro 4/3rds setup with a proper fisheye lens. may have the opportunity to go abseiling to take some shots of some window cleaners in adelaide soon, if that happens then i'll be thinking about a new setup a bit more seriously.
Lytro
The camera that turns light into living pictures
This year, Lytro will debut the first light field camera for everyone. OK – you’re not everyone. You are a beautiful, unique snowflake. And you deserve an amazing camera that lets you capture life’s singular moments, like baby’s first steps not second, with maximum magic and minimum hassle. No more fighting with dials and settings and modes. No more flat, boring, static photographs. With a Lytro, you unleash the light.
Looks really interesting. I wonder if this will change digital cameras much?
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
