  • Replies 161
Posted Images
Went out to with my mates VP SS for a shoot last night. Found an old abandoned petrol station full of grafiti and random stuff, so we had fun checking it out. Although we got the attention of the lady who lives behind it, then the cops turned up... But no dramas, thankfully.
There are more in my FB. Grabbed this one from inside the workshop, love how it turned out! Not bad considering it was completely pitch black ;) But of course we didnt go inside officer... :P
ended up buying an olympus e-pl1 for $360. the lens i want tho is around $800 grey import (panasonic 8mm fisheye. half the weight of the olympus fisheye and doesnt need a 4/3 to micro 4/3 adapter saving $300). will be worth it for the higher quality of the pics once i have saved up enough. time to start trying to get permission to take shots from the higher profile buildings, not sure how that will go. have a feeling it will involve spending more money on roof access type safety courses tho, lol. would be worth it, would love to specialize in photography from high places. something about being high that fascinates me, im scared of heights, but am too addicted to give it up, lol.
either that or i need to road trip to other cities for some rooftopping missions, lol
and your right about that shot, i left it a bit late to get up there, i need to finish up half hour earlier and be up there ready. would also like to bracket it next time and do a night HDR so all elements are exposed properly. that burnt out statue irks me, lol.
Ah nice! So the E-PL1 is body only atm?
nah, it came with a 14-40mm. they are all going out cheap as the e-pl3 has been announced.
i still havent really taken it out and used it, i prefer the flip out screen on the G11.
only bought it for higher quality fisheye photos anyway, so probably wont get used till i have the lens for it.
loving your light painting shots RM, keep it up!
so many cool pics in this thread so far this month.
lol, I actually quite like this photo of me.
probably cause I cant see my face, haha.
also love how the three buildings behind me just seem to melt into the sunset, lol
Edited by Jay019
you should be a rep for gopro!!!
if they send me out a full HD cam with the LCD backpack i'd promote the shit out of them, haha.
but check out GoPro Photos on facebook, some seriously epic shots can be taken with such a simple little setup.
Edited by Jay019
Been a while since I've posted, or even really had a proper browse. I've been damn busy getting these rig shots out and getting the new site up and running.
www.autocult.net
have a look, got any thoughts of feedback, I'm happy to hear it? I even made a facebook for it haha, go like us!
nice shot J. that's your best face yet ;P
that's not football :P
A few more rig shots...
Edited by MaTBoY
Stars by Ben Isaac, on Flickr
Light Pollution by Ben Isaac, on Flickr
Milky Way by Ben Isaac, on Flickr
Stormrise Seascape by Ben Isaac, on Flickr
Just got my new Tamron 28-75 f2.8. First attempt at some nightscapes. Deliberately used a large aperture to try and avoid 'star trails' as I was going for 'as if you were there' kind of look.
damn half you guys for using hosts i can't see while at work! GRRRRRRRRRRRRRRRRRRRRR (mainly at work)
had another shot get explored on flickr :)
this one.
and these are the last 3 from the group rig shots.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
