If your talking about putting a spring on the actuator to the the wastegate flap arm, that is one of the first big no no,s to do with a turbo for boost control. There have been many an article written by Martin donen about this back yard fix.
He writes all majority of the tech articles in a heap of car magazines. Zoom and high performance import magazine are two that instantly come to mind.
If your modifying the factory actuator like that, I would spend the $140ish and just buy a new adjustable 12 psi actuator and increase the preload from there. Much safer than whacking on a spring.
Ah well if its working for you thats good, I wouldnt even contemplate doing that to my cars. The best form of boost control is said to be mechanical but only by using the correct pre set adjustable actuator or external waste gate with correct spring. If using an EBC they say to have a mechanical setting of minimum 50% of the max boost set.
There are no aftermarket options for us. I only replicate the heavy actuator with the externally adjustable spring to upgrade the stock 7psi one, making sure the spring pulls straight is the key. Its much smarter than winding a heap of preload into those adjustable ones you see around and it fails in the "low boost" setting for most of the scenarios I have thought of, unlike those.
There is no difference in operation between my spring on the side mod and a 17 psi hks actuator so I don't know why everyone is so against it. Come up with a better reason than "its backyard" and I will discuss it as all my mods are backyard. lol.
Martin works for/runs Willall Racing in SA. Specialise in R35 GTRs these days I think. Knows his stuff. But I don't know what he said... :whistling:
And arguably one of the best tuners in Australia, looking forward to getting him to have a stab at the M35 over the coming months
I'm all for yard yard mechanics, hell, I've been building my own engines and modifying my cars in the back yard for 20 yrs. That's just one mod I wouldn't touch. No offense, just my thoughts.
Edited by slippylotion
fair enough buddy! appreciate the heads up though, im sure if one of ours fails it'll be mine lol and ill be the first to let everyone know.
Whatever works for you I guess, if you come up with a better option I'm all ears. The 45mm external gate is working fine too but it's still dropping 4psi by 7k. The 1 bar spring isn't enough to hold 20psi let alone the 2 bar it's running ATM.
lol 2 bar.
Let me know how you go. The tuner I was going to use still wants to persue the Haltech option, which admittedly sounds better (in theory), even though I've bought an eManage :down:
Don't waste the dollars on a haltech unless its the ps2000
Funny, he says he can do an Emanage tune, but can't quote accurately, so I take it that means he hasn't.
Haltech option is a new unit which works with 350Zs, so they figure it'll work with VQ25s using the same trigger pattern. I have a quote for $500-1000, but no guarantees it'll work.
Seriously considering getting Cian to do it when I come over for Gymkhana World Tour...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
