Yeah, am noticing the "asthma puffer craze" coming through, its weird how some people work. One customer before their PT session whacked in some sprays, PT asked have you got asthma? client responds with "no, i cant do anything really energetic without having it"
Made me look up addictions to the stuff, but found out it was more the light headed feeling the client liked prior to training......
Strange.
  • Like 1
Got friends addicted to nasal sprays and eye drops...they can't function without them. Like any drug used over extensive periods, your body adapts to it eventually and heavier doses are needed in conjunction with the deterioration of the body's natural system for that particular function. Vicious cycle.
What chemical would they be addicted to in the nasal and eye drops?
Have you guys seen that show on TV that is on now about strange addictions?
Amazed how many people are addicted to drinking dishwashing fluid and clothes powder, oh and not to mention Chalk!! The lady even goes opn about what flavour chalk tastes the best!! *white obviously!*
I hate when people say CLEM instead of CLEN.
Or worse, GLEN.
Clen + t3= win apparently. Who has stuffed around with both at the same time?
Hahaha..Guy I know is always trying to sell me Clembuterol... Don't have the heart to correct him
Clen and t3(cytomel) together will hypercharge your metabolism and fat loss but consider compromises in muscle gains, hence experiencing muscle loss. I wouldn't bother with t3 as it may alter your natural production of t3/t4 and potentially lead to hypothyroidism. If it has worked wonders for some people, then I could be wrong.
We had a patient that was taking thyroxine, but the prescriber had given her the wrong dose and dosing schedule, it was picked up when she came back to get her following 3 months supply and she had dropped 19Kg (was almost back to ideal body weight) that stuff shreds fat by turbo-charging your metabolisim. All this from being on 200mcg instead of 100mcg. As mentioned though there is a massive price to pay by supplimenting you natural balance of T3/T4 for that long. I've seen low doses ie 50mcg used for month on/off cycles with no apparent harm, probably as relative as getting testicle cancer from steroids...some poor bastard is going to be unlucky, while a good majority are fine.
Was going to say, it's more the fact they take the place of a natural bodily function, which will cause it to cease/adapt after extended use of the medicine...but as per Terry's post, there are obviously chemicals in them responsible for it. Like most topical medicines, there are recommended time frames of use, e.g. 6-8 weeks. Use it all your life and you'll be on it all your life...
It's scary what people develop an addiction and proceeding immunity to. The addiction to swallowing detergents is probably an onset of OCD compulsions, cleanliness gone way too far. More common is people brushing their teeth multiple times per day or using unnecessary amounts of toothpaste.
The chemical in Nose Spray isn't addictive, it's actually damaging phsyically to the nasal gizzards.
So if you use it too often/too long, damage gets done and you lose things like sense of smell, and you'll find even after stopping use for 6 months your nose is more blocked than normal etc.
Bit different to a dependancy/addiction when its actually damaging.
Eye drops though i can agree with, the body will stop naturally producing its over fluid if you use it for extended periods. It's similar to shaving. Shave every day, your beard etc grows faster. I found shaving every 3rd-4th day, it grew much slower as a result.
Sh*t, any chance you took her blood pressure throughout this time? Would love to see if she was stage 1 or 2 hypertension?
She avoided any follow up appointments with her GP as she liked what was happening with regards to weight loss. The only reason she popped up again was to get more medication. Denied! Go straight to your GP do not pass go.
I have heard this is a massive myth? Any substance to it?
I know a guy at the moment, EATS LIKE A HORSE and is still cutting up due to turbocharging his metabolism.
In addition to the T3/Clen, he is running Tren/Prop (he competes).
Strange.
Wtf that person has issues... dude wish I was taking it for giggles I hate that feeling but I hate the asthmatic synosis from not breathing more. Stupid chronic asthma!
  • 2 years later...
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
    • Thanks guys - I have been overseas for a hectic many weeks , so haven't had time to chase any of these up.  Some of the suggestions are for 4.1 ratio, which I already have, and a 3.5 at Lonsdale, which is also too tall.  Really looking for 3.9 or even a 3.7 LSD, either with M12 bolts. Will look some more.
