Want to run on E85, yes, and make 350rwkW on this turbo and push for more later in year.
Aero wise, fitted rear difusser and vortes generators ( varis or voltex, not sure, off an evo ) and will be making front splitter and some sideskirt changes before the event. Also made changes to suspension. Car is a 98 model. Bought it as stock road car 8 years a go!
Nice work Andrew looks very promising good luck matethumbsup.gif. I too know the feeling of a 3yr project as my R32 GTR took the same amount of time and I can't get the grin off my face every time I drive it, this video has inspired me to go all out of my 33 GTR now... time attack here I come.
Running shitty old R888s now. 255 front and 275 rear. For WTAC will run 235 front and 265 rear super soft Hankooks but will later modify gurds to fit 265 front and 295 rear.
Share your secret where you get the tyres from?
Why run 235s at WTAC when the car run fit 255s now? or do they scrub significantly?
nice one mate. 1:06 for a first test day is pretty rapid. should be very quick once dialled in. looks bloody quick for 270kw too. they must be real kw not the inflated kw everyone talks about...
hope it goes well for you at WTAC. :)
Show queen to track hack.
What was the inspiration for the change Andrew?
What?!! It was always a STREET car that looked good. It got thrashed hard!!
Too hard having a car like that on the road. A blown oil pump meant I pulled the engine out, then I decided to '"tidy" some things up and re-do things I wasn't happy with. One thing lead to another and BAM, a bare shell S14.
A track itch has been there for a while. Starting a new business and running it meant the build was a bit slow is all.
That and Time Attack is sick
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
