  • Replies 244
Posted Images
Paid and Faxed :)
Simon Henman
Going to be my first DECA.
Super excited for this one.
Edit: Can we get an update to the OP re: No. of Entries?
Edited by Odium
I faxed my DECA form early this afternoon, but wasn't a member of SAU-VIC yet.
Applied/paid for SAU-VIC 30 mins later...
I left the Club Membership number blank on the DECA form, is that going to matter too much?
If so, Could you guys please add in Simon Henman's new SAU-VIC number (yet to be received) to my DECA form?
Cheers :D
There's a name I haven't seen in a while!
Wow. Long time no see. Good to see you are coming along.
Indeed, hanging to chuck the new car around the pan. Gonna miss the RWD shenanigans though!
Hey Simon. You don't need to be a SAU Vic member to do deca. It just has a spot on the form for you to put it in. So no need to update the form.
In saying that feel free to join and become a SAUvic member Simmon.
Would be great to have you on board.
Cheers WayneO
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
