  • Replies 244
Posted Images
Daniel I want a good look at this E85 voodoo ;)
hahaha, i'll drive up with 98, prob like half a tank or something, so when i get to Shep it'll be pretty low, then i'll put in a couple jerries of E85, which i rekcon should be plenty for a day and then fill up with 98 on the way back if need be :)
will prob bring the laptop to see what the E% mixture is before the runs start, but not much more i can do as i have no tuning knowledge. But if Trent says he's happy for the car to do track work with Flex-Fuel active, then i'm happy :)
Hey Leon,
Name for driver 46 is 'Akshay' Rajan not Ryan. Also, 46 and 47 would like to share the same car, so I guess we need to be in the same group but enough numbers apart? :ermm:
Had heaps of fun at the last one (which was my first) can't wait to go again!
Cheers mate!
G'day guys,
I am really excited about my first DECA. Looking forward to seeing what my GTR is like. Could you please update my name.
Driver number 41 - My name is David Hemmings -
Not Davis Memmings.
Thanks Dave
Hey Leon,
Cheers mate!
sorted... .46 and .47 are just numbers for now and your'grouping' numbers you will be 10 cars apart
hope you have as much fun on this one as you did the last! :cheers:
G'day guys,
Not Davis Memmings.
Thanks Dave
Nope... Davis Memmings is who entered and thats who we will be looking for on saturday :whistling:
G'day guys
Thanks Dave
Yay, welcome to SAU Dave...
See you tomorrow morning bro, its car mod time :D You're going to love the Long Wang, even though I know you're used to Short Wang.
(Leon, I'd like to be in the same group as my mate Davis Memmings, if that is something that matters at this point ;) )
Cheers,
Simon
Dammit, even google image search is trying to change his name back to how it should be.
so how exactly does the competition side of things work?
you've got the short and long wang, which are timed... does this get converted into some sort of points or is just +mins/secs from the fastest person?
and from memory, there were some penalties for hitting cones etc?
and the skidpan is a mixture of time and penalties for cones?
Pretty much it is that, from memory on wangs you get points for fastest.
I have a tip for you, keep away from the Armco barrier at Enormous Penis (aka Long Wang).
There are points? I thought the aim of the game was to drive around mashing cones and looking stupid.
ok, got it.
for those that are interested...
"DECA Rounds
Each Sub-Event of the Event will be scored individually.
Points will be awarded in order of finishing from highest to lowest as follows:
1st = 50 points,
2nd = 49 points,
3rd = 48 points,
4th = 47 points etc, and so on down to the last competitor.
All points from each sub event are accumulated and a total is created with the highest score winning. Classes are AWD and RWD.
Penalties:
Hit Cone (Make a cone move from it's spot) = +5 Seconds Per Cone
Missed Gate/Cone (Wrong Direction) = Slowest Time + 10 Seconds.
Did Not Finish = Slowest Time +10 Seconds
Did Not Complete Full Course = Slowest Time +10 Seconds (Missed more than 3 Cones)
Did Not Start = No Score - Nil points"
what's classified as a decent time for the short and long wang?
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
