  • Replies 244
Posted Images
From memory long wang anything under 55sec is pretty good. Best drivers on mini wang get under 25sec.
Good to know, I'll be aiming for about 1m20s then :P
How do you guys normally travel up there?
I'm heading up on Friday Night after work, do you normally convoy up there or just meet at the Motel?
Was planning on leaving from Melbourne CBD at approx 5:30pm or so... (picking up a few guys from the city on the way)
Good luck with that! Ring Rd will be standstill until at least 6.30-7pm
Either leave by 3pm or don't bother until after 7pm. It'll take you an extra 45-60mins if you try and go in peak, if not more. I tried it once, never again.
Ask your boss to let you go early Simon. I'm leaving Doncaster 4.30 - 5.00. Last time I left straight from work at 4.30 it took a really long time to get to the Hume. I'm just glad I didn't leave any later..
Ha, good point :P
Bit tricky with the guys I've gotta collect on the way...
Meh I'll give them some notice and they can suck it up and leave early as well.
:thumbsup: <--- Good friend.
Or just go and sit @ pub for an hour or something and wait for the traffic to die off if you cant leave early.
Ive done that before (when not the driver). As it beats sitting in a car for an extra hour
Or just go the back way like I do (if you happen to live close enough) through Yea & Seymour and you avoid all the traffic.
That's axactly what I'll be doing this time as I'll be leaving after work and will be wanting to avoid the traffic!!!
I cant remember the last time I worked on a DECA Friday :(
I'll probably oraganise a convoy up on the Friday night if anyones interested simply because there's like 11 of us in our group going up together.
I owe you drinks this DECA mofo, ps I'm going up Friday night too!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
