Hello,
Sorry for the plain question, but ->
I'm about to replace my fuel pump ..
I was wondering how the fuel pump+cradle is actually mounted to the chasis.
From looking at the manual it seems there are no bolts that attach the pump assembly
to the car (fuel tank) ?
It must be secured somehow .. musn't it?
https://www.sau.com.au/forums/topic/371704-r33gtst-fuelpump-how-is-it-mounted/
The top of the fuel pump cradle slides down onto a bracket that is mounted just inside the fuel tank. It's quite hard to explain, but if you open up the lid of your fuel tank, you'll see what I mean. To remove, you have to slide the cradle up and off the bracket. It's fairly self explanatory and easy, the job is just a bitch because it requires small arms and contortionist like flexibility. Probably not that bad if you're just replacing stock for stock, but upgrading to a bigger pump has some fun trial and error to go with it.
Hi there,
Many thanks!
Yes, I thought so (I mean that there is a bracket) ..
So the cradle just slides on it, and nothing to secure it (like a bolt or clip?)
I have a Tomei-Pump which is supposed to be a drop in and forget, so that will be (hopefully) painless.
I also need to pull the fuse off the pump and then let the engine idle till the fuel pressure has dropped, right?
Nothing to secure it...it relies on gravity, plus it slides a fair way down on the bracket, so it is fairly secure. In fact, when I put in my Bosch 040, I could only slide the top of the cradle half way down the bracket and it's still secure.
Don't know about the removing of fuses and engine stalling...I did mine without all this...shouldn't be any pressure after you've had the engine off for more than a few minutes.
days later I had fuel squirting everywhere lol just cover it up with a old towel when you remove the lines.
Oh ok...maybe changes in air temperature pressurised your fuel over time :P
There was seriously very little, if any, fuel that came out when I disconnected the lines...so I don't know what's going on there lol.
just put a nismo in my 33gtst, very easy, probably took 15 minutes of dicking around just trying to get it back on the cradle though. replaced a bosch 040 that i just couldnt get back on, and i easily spent over an hour on it and gave up.
Just put a torch in the tank when you've removed it and you will see how easy it actually is to put on
Hi ...
How do I remove the fuel lines (the 2 with the quick fit connector)
How does the connector work? (sorry, never seen these before)
Also did you use a hammer to remove loosen the big plastic nut?
(I would make a tool for this, but don't have the time at the moment ..)
Thanks!
i just used pliers to squeeze clamps together then pulled the hose off. although i had trouble with the feed line and ended up replacing it with new line, only because the feed line had no extra slack in it, i think it was about 63cm long so i just got 70cm worth.
i just used a big flathead screwdriver and a hammer to get it off
The top 2 hoses are return and the bottom one is the feed. Is that what you meant by connector thing?
or the wire connector? its just acts like a connecting point with wires both side
bracket intank
Hi ...
Thanks!
Hi there,
Thanks for the pictures and advice :)
I have attached a pictures of the hoses, I hope that makes it clearer.
(I have a Spec2, so I guess that's why I have these)
Edited by Torques
Hello there,
Just wanted to report that I recently changed the pump to a Tomei.
It all went alright, and the hardest part was probably fitting the fuel pump back in.
This was due to my big hand and the limited space in the tank.
Also I should have emptied the fuel tank more; I got quite dizzy from the fumes and my skin being
washed in fuel.
Hi there,
  • 8 years later...
Sorry I’m new here.     I am having a shocking time trying to work out the pump cradle mounting.   As it wasn’t mounted when I removed it
Well I hope you have a low fuel level because as a first timer it helps you to see what you need to do.
The cradle is a longish flat looking bracket that slides into and then clip locates in a plastic holder on the front of the tank.
Have a look, stand back and use an LED torch [try to avoid arcs and sparks] and see if you can see and feel the plastic holder.
Once you do you will sort of realise how the bracket slides down and then clips in place.
There is probably a tutorial in the How To section on this forum that will help, and good ole YouTube is always a 'go to'.
Maybe this:
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
