hey guys
well i am nearly shore that i dont have the stock r32gtst brakes on my car
a mechanic has told me they are gtr r32 brakes....
some guys on the forum i have met up wit me have told me r33gtst brakes
well to the point i am up for new rotors and i have seen a guy selling dba rotors on here for cheap soe has gave me the price for
r32 gtst rotors but will this fit since i have these brakes on my car
this might be a stupid question but if anyone noes it would be a big help for me
thanks
https://www.sau.com.au/forums/topic/372618-r32-gtst-brakes/
hey guys
thanks
Pics?
https://www.sau.com.au/forums/topic/372618-r32-gtst-brakes/#findComment-5943309
well boostn imports has contacked me after i asked if they would fit ( the guy who sells the dba rotors) and he says they wiill fit even if they are upgraded rotors
i am guess since he seels alot of parts on here he will no
https://www.sau.com.au/forums/topic/372618-r32-gtst-brakes/#findComment-5944319
R32GTSt are 280mm rotors.
R33gtst and R32GTR are 296mm rotors (IIRC 32GTR is 2mm thicker).
If you try to run 280mm rotors with calipers meant for 296mm, you will have a bunch of pad hanging over the edge.
If you try to run 296mm rotors with calipers meant for 280mm, you won't be able to bolt the caliper back up.
https://www.sau.com.au/forums/topic/372618-r32-gtst-brakes/#findComment-5945614
  • 4 years later...
Bumping and old thread, can anyone tell me what brake callipers are in the first photo, supposedly the second photo is r33 gtst ones. Car is a 92 r32 gtst.
Thinking of buying the upgraded gtr gktech rotors with adapters because they come in similar pricing as some good DBA rotors..opinions on pads?
Edit: measured the rotors on the car, 280mm which means they are 32 gtst? And my spares are 296mm which means 33 gtst or 32 gtr. The front gktech gear doesn't fit with r33 gtst rotors though because if the rotor width difference... ( http://www.gktech.com/index.php/z32-r32-s14-s15-caliper-bracket-to-suit-324mm-r33-gtr-rotor-1.html ) would you buy the gk gear, or put 33s on there? Either way I need front rotors and I'm not sure what's better
Edited by Walfers
https://www.sau.com.au/forums/topic/372618-r32-gtst-brakes/#findComment-7638083
The calipers with Nissan written on them are 4 piston Sumitomo calipers, the R32/R33 Turbo coupe models use them as do R32 GTR models.
Edited by GTRPSI
https://www.sau.com.au/forums/topic/372618-r32-gtst-brakes/#findComment-7638187
This stuff is really not that hard.
R32 GTSt calipers are easy to space out to the 324mm rotor that many want to space out to. The dogbone adapters for that are a good design, everything goes together well.
R32 GTSt calipers are impossible to space out to 296mm, so you can never fit them onto R33 rotors. Nor would you bother when you can just buy some R33 calipers to go with 296mm rotors.
R33 GTST calipers can be spaced out to sit on a 324mm rotor, but the dogbone design is not excellent and you will probably need to grind some caliper material. (To be fair, you might even need to do that when slapping 32 calipers onto 324mm rotors also, because the calipers that suit smaller diameter rotors don't necessarily have the right 'curve' to fit onto bigger rotors.)
Nobody will be able to tell you which calipers are in either of your photos, because it is the length of the legs that is the main difference between them.
https://www.sau.com.au/forums/topic/372618-r32-gtst-brakes/#findComment-7638223
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
