Ok so I have my M35, and I have a wing coming from Japan. Once that's painted and a few minor repairs on the body are done, it's time to have some fun. I have around $5k to justify spending on top of the car, but could be convinced to spend more, just don't want to go mental.
Goals for this car is to retain driveability, comfort, reliability and a degree of economy while handling well and going alright. We only have one car in the family right now, so really the Stagea is meant to satisfy my wants of having something with a bit of go, and my wife's wants for getting herself from place to place.
The car is standard aside from a Blitz intercooler and K&N filter. It has a Nismo exhaust. Are they decent at all? Worth having a bigger dump into a quality cat and then just run the Nismo exhaust or does it really strangle the system?
Now that many of you have done what you've done, how would you go about doing it again? I'm keen to get coilovers in this thing first, but aside from that have no real plans for the future. In all honesty, I don't really need massive power, but a highflow seems like the way to go rather than have the car give out on me at some stage, would you agree?
Anyway, keen to hear peoples opinions.
https://www.sau.com.au/forums/topic/373090-m35-mod-path/
  • Replies 151
keep some cash aside for a turbo rebuild. like many of ours it may be the first thing that needs rebuilding(read: highflowing)
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951214
when you high flow the turbo from my understanding u also need to upgrade injecters, fuel pump and fit a E-manage or the like........ so that in itself will cost upwards of $2000 in just parts.
apart from that make sure u dont have the stock dump pipe and the nismo exhaust should be fine, FMIC and A/F are good.
then just spend money on coilovers ($1500ish) maybe some strut braces etc
$5000 doesnt go along way really..................
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951216
who said? lol you dont need to, but if you wanted to pull some power out of it, its advisable. with a budget of 5k I dont think the OP was consdering tuning?
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951217
Not necessarily true; Injectors/Fuel pump/Emanage is only necessary when you start chasing numbers. Ive had a high flowed turbo for over a year without needing to do the above.
You can choose NOT to do the turbo but it'd be silly to expect it to last forever; you can either wait for it to let go or pre-empt it with an upgrade. There are a few rebuild/highflow options - if you're not chasing numbers then you should be able to get away with a rebuild in the region of $1k I believe & this will be pretty close to stock spec with the advantage of a steel wheel and a touch more power/response.
Bang for buck, Plenumn spacer would be the first & easiest thing to do.
After that, ensure the ehaust dump doesnt have the cat in it.
Sway bars will definitely help with going around corners.
Thats my 2c at least :)
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951225
keep the boost down and youll be fine with a hiflow on stock everything else.
5k isnt massive, but its enough to replace all those ageing parts that really need doing!
budget at least $1000 for labour for the turbo change. depending on who does it for you.
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951226
Yeah see this is the thing. It's hard to justify high flowing the turbo, but at the same time it's probably the most unreliable part in the car. But if I go and high flow the thing, it kind of seems like a waste not doing it right.
Sure doesn't!
I'd be keen on getting it properly tuned, but I know I don't have the cash for it. Not unless there's a cheap solution that just magically appears overnight but from everything I've read it's not going to happen.
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951227
well you can get an emanage for around 500-600 brand new. and a tune depending on the tuner from 400-600 including install of the unit.
might have to drive down to melbourne for that, as theirs still only one proven tuner unless i stand corrected
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951233
No sorry, I mean what would be better:
a) dump + cat with Nismo exhaust back and Emanage and tune, or
b) dump + cat + catback, no tune.
as iain said but is your "front pipe" still standard? or is it and upgraded part aswell.
any modification will obviously perform at its best with a tune. you'll mac out the suction pipe at about 190kw IIRC
there is still a part of the exhaust between the dump and the cat back.
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951279
If you've got the Nismo exhaust, dump and front pipe for sure. Get rid of the cat in the dump as a priority! There are a few options at the moment, I've got the AM Performance pipes on mine and I'm local to you if you want to have a look?
What needs doing on the car? Mine needs brake pads and rotors, suspension, etc. You can easily spend $2k+ doing just this. Sway bars are a must, mine are brilliant. I've done strut brace instead of plenum spacer, but they're pretty highly regarded.
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951291
$5,000 aye.
Providing you do most of the mechanical work yourself.
Turbo back exhaust(including dump + no cat), Standard rebuild of the the turbo with steel wheels, E-Manage ultimate + tune, a Turbosmart boost controller and a set of BC's.
Spent!
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951437
Jasevr4, is this the silver RS that was/is on Carsales?
If so, that Nismo exhaust is the same one I have and you shouldn't change it.
It has effectively the same piping as the Fujitsubo Legalis with a completely different rear muffler.
1. Get a dump pipe/front pipe combo to bolt up to your turbo and the Nismo exhaust.
2. Drill out the oil restrictor to 3mm which may prolong the life of your turbo.
3. Get a set of BC's.
You should still have a couple of grand left so I'd go with a boost controller and tune I guess (eManage Ultimate is the cheapest option).
Doing so, you'll make more power, have less stress on that flimsy turbo, have far better handling and probably better fuel economy.
If you want more power after that, you'll need a suction pipe, injectors and pump... and probably a new turbo lol.
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951466
thhhhiiiisss! i forgot to mention
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951468
I agree with Cam, dump/front pipe, EMU and tune for 20psi on the stock turbo. As long as the oil restrictor doesnt get blocked it should last, mine did for over 4 months. Then save for the turbo rebuild...
(Aaron, I think 2.5mm would be better)
https://www.sau.com.au/forums/topic/373090-m35-mod-path/#findComment-5951482
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
