2nd hand nardi classic
Really? Dont like the old style wheels lol hmm i need something with abit of white in it as my theme is white and grey, something like black leather silver spoked and some white in there somewhere who knew it was so hard to find a steering wheel im so picky arghh!
but for $200 including a boss kit (which vary from $50 to $100 on their own) you are looking at second hand or chinese copy stuff only. not going to find a genuine italian made leather momo or nardi for $100-$150 new... still nothing wrong with used if it's good nick. given it's something you use all the time though maybe consider saving a few more bucks and hold out for something nicer?
nardi deep corn
Enough Said!
Nothing wrong with the classic Nardi. i have one slight dish looks amazing and oldschool but still very modern and sleak. (also not totally out there on the PO PO radar)
However i also bought an OMP corsica (I think) in suede, mate has one on his drift car and it was amazing when i drove it so bought one.
If your an ebay fan, maybe check ebay UK for OMP and also Nardi at good prices. dont get a chinese or thailand copy get a real one. They just look better!
I found in 5 mins a couple of good ones on ebay UK (most genuine ones were in boss kit sets for Euro cars) maybe PM sellers to see whether they can ship just a wheel at a cheaper price given the Boss kit will weight a bit.
I would really recommend OMP. just feels so nice! and in the Gtr sits you back in the seat and great turning response. Flat face will sit alternatively rather forward depending on your driving style setup etc etc.
hope that helps!! whatever you do. if you can dont cheap out and get a shpecked up Ebay wheel get a decent one for a few hundred max or second hand and a nice boss kit. your car will thank you!
screw your theme, nardi deep corn FTW!!
Honestly it looks like its good quality but the look of it doesnt do it for me. Did you see the link i put up on ebay i want something like that. ^^^^
i did, honestly ive never liked the look of any of those sort of wheels. i just cant help thinking that they wouldnt look out of place in an old commy yucky.gif
imo go for either a nardi classic
or the momo wheel suggested by N1GTR
see choosing either of those largely depends how you drive as well..While the nardi is more a drift wheel the momo style is a racers wheel.. those little hand grips promote confidence somewhat when cornering at high speed but they just get in the way if your sliding..
however if you dont plan on driving or sliding then just get whatever you think looks cool :D
MOMO Race
This is where I got mine from, seemed a bit sus cause it was so cheap, but mines genuine and in good condition
That 'Nissan' Wheel looks like a MOMO race with a big Nissan horn button from another steering wheel stuck onto it. Not nice at all. If you want something like that then you should just buy one of the Nissan horn buttons off ebay and replace the MOMO horn button with that. Would look alot nicer
No, the one the OP likes is truly, wonderfully, Awful!!!!
haha Yeah that saas is just cheap and tacky, the Nissan Momo is quality, but very ugly..
the one 89cal listed is very nice..I'd say its a winner.
so what does everybody else have, I got an Ol skool Fittipaldi wheel like this..38767874383_large.jpg
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
