Hey everyone,
thinking about selling my beloved 88 camry for something newer and more economical.
im looking at a hot hatch, i dont really care how feminine it looks, not looking to impress anyone, i need fuel economy, manual transmission and 2000 model +, pref 4 but 2 door is fine, looking at no more then 1.5l and no less then 1.3
so far ive been looking at the
Hyundai Getz 02 model- 1.5l (seems more fuel efficient then the 04)
Toyota Echo 03ish model- 1.3l
Toyota Echo sportivo- 1.5l
possibly copy my sister and get a swift?
just looking for something cheap, around 8 grand, very economical, but one catch i need it to be able to climb mount eusley probly once a fort night and get me to newcastle from wollongong.
wondering if the echo 1.3 would be strong enough to get me up there alright??
give me some suggestions of your favour eco cars :D nothing over 10 grand as im buying a house and going on a euro trip next year :D
https://www.sau.com.au/forums/topic/374144-thinking-of-an-upgrade/
OK, I haven't checked any of the values of the cars I'm suggesting, but if you want something small, light and economical but still fun (i.e. ignore the Echo/Yaris and any of the Korean or Malaysian options):
  • Honda Jazz
  • Mazda 2
  • Ford Fiesta
  • VW Polo
  • Suzuki Swift
Lol, march superturbo??
More seriously though, if you just want economy, as in dollars saved. Keep a lookout for thing's like camry's and magna's etc on ebay and carsales that have had an LPG conversion with a vapour injection system. They get similar and sometimes better economy but the fuel you're using is less than half the price.
Just a thought. A newer, smaller car would be better through the twisty bits.
Hmm I didn't think of the Mazda 2 I'll check it out,
Id agree that the jazz is better, power windows and 4 door :) I think I'll be looking for one of them.
I can't get a swift because my sister has one :P would be a little weird.
Hmm I've heard there's lots of problem with the holdens with LPG conversions.
Would this apply to a canry would you think??
Not sure about holdens, I've mainly looked into the magna ones. The vapour injection system is nothing like the oler mix systems. And the liquid injection systems have significant power gains.
To find an injection system you'd be looking for someone selling a car who has spent 4k on the conversion (before the rebate),, but I have seen a few camrys and magnas on ebay.
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
