No where as pretty as yours :P
Has been produced to the base vehicle is a good level GTS2.5 ECR32 1993. Vehicle is certified.
Since the inspection has expired, passed by wiping.
Fabrication shop is Mr. Zenitani.
Other remodeling underbody engine, parts produced in the new, post-production, is 2 Owners by me.
After the production run is about 8000km.
Of torque in the engine and the 3150cc, up to 9000rpm, and around, rather than stress from bottom to top.
NA, 6 slots, six straight, will sound good.
For example, the drive system to run the car engine is now very good condition.
Well have heard Nonsuri.
What Hakosuka how, to swap Kenmeri production?
No rot and also fixed frame, there are no major damage due to accidents in particular.
Body side is clean and the floor, trunk, and legs around. See, please include images.
There is no problem gloss exterior color, dent is located at several points.
Equipped with power steering, power windows is about, do not have air conditioning and heating.
As point defects, it is time to replace the tire. Now I have disconnect horn button is missing there.
Vehicle underbody engine is certified mission, I think about and ride height adjustment of the catalyst they need at the time of inspection.
Engine
12 RB30 block + RB26 head high cam lift 70 ~ 72 ° 10,5 ~ 11,88 Φ piston, compression; 1,
expansion port polishing, beryllium copper valve guide, Ken head surface,
boring dummy head, one-off throttle specification Carl funnel 6 stations,
crank full balance, adding oil jet, mirror finish connecting rods,
metal head gasket, cam slide pulley
F112 metal, oil pump strengthening, strengthening water pump, one-off stainless steel exhaust manifold,
Cooling
Aluminum Radiator ARC + collector tank side tank, HKS oil cooler, electric fan, Cusco oil catch tank
Drive system
+ Prop shaft speed ECR33 5, Kurtz 1,5 WAY12kg, twin plate clutch Technica,
autoselect Klux harmonic drive, Pirro TEIN tension rods,
Cusco upper arm, GTR stabilizer + caliper, rotor F endless, CCM Pat,
master stopper Tomei, APP stainless steel mesh
Edited by HKS26T
  • 1 month later...
Friday night I chucked the 4.11:1 ratio 1.5way mechanical kaaz in with some bushes, found out at the end I only had enough lower control arm bushes to do one side, passenger side got left out :(
But yeah one of my customers paid for me to go track day so I got some practice before nationals :D big thanks to HKS26T
http://www.youtube.com/watch?v=1iJP9XUrF6U
I need better tyres and skills (which will come in time)
my personal best is 1:29.7
Steve got a best of 1:23.2
Steve showing me the racing line and where to brake and turn (I'll get there one day)
http://www.youtube.com/watch?v=X9ugzV-oaVQ
And driving past the pit wall (I wasnt aloud to stand any closer :( )
http://www.youtube.com/watch?v=ZtvJOIyA6wU
Was fun, will do it again with more sleep the night before hand, though I think I done some damage when I hit limiter in 3rd in one of my last few laps :(
today did a compression test
1 225psi
2 227psi
3 220psi
4 220psi
5 235psi
6 240psi
the fuel had sealed 5 & 6 and acted as if it was a wet test, and hour later, 225psi on 5 & 6
plugs were fouled up pretty hard, CAS was a tad loose
I got new plugs - no change
Leak down test - 4% on all with 5% on #6, leaked past rings, had oil mist come through breather and oil filler cap
Oil pressure - only had imperial fittings so not able to check
Checked the timing, it looks like the intake cam and CAS went full retard (never go full retard, tom hanks, looked retard, act retard, could play ping pong, not retard)
I played around with it and I think I've got it close to how it sounded in the originally, ticking noise left after adjusting the CAS, squeel has disapeared after top timing cover came off
Will need to go back on the dyno to get it perfect again
  • 2 months later...
small updates;
new seat
new dash
got new wheels
Got Flares
thursday night;
7:30pm trailing arms came out
old bushes next to new ones
8:30 trailing arms went back in
9pm leaving maccas
9:15 noticed dash was dull
9:20 car dies on cumberland highway, alternator belt had snapped :(
organised a spare :)
push car to start of right turning lane
notice slight bubbling noise from radiator :(
Pulled everything off to get ready to put new one on
Phone dies
numerous people stop to ask if i need help, only 1 dickhead :)
Many lols were had watching people getting caught by safety camera, i waved in a few (stolen idea from top gear)
So many morons still attempt to join the cue behind my car while im sitting on the boot
some even locked their brakes up cause they were too busy on phone to pay attention
spare belt turns up
cant access his battery
he persists in flagging down girls in hatch backs, 1 nearly successful
he calls a tow truck, he heads off as he has work,
girls come back, no jumper leads
11:30 tow truck turns up
11:31 tow trucks heater is awesome
11:40 home
11:45 batter and booster charging
6am reconnect battery alarm goes off, drains battery
8am buy new battery
8:10 off to Marulan
10am road works, didnt see entry after bridge, tom tom takes me down a dirt track
1pm i finally get off my butt and sign on
got 3 and a half sessions in, power steering belt kept coming off, and i got black flagged for exeeding noise limits (i stayed in 2nd as it picked up quicker and would nearly rev all the way out before the next turn)
http://www.youtube.com/watch?v=3Lr47p0gW1s
http://www.youtube.com/watch?v=_OLy2hh1ihk
got new power steering and water pump belts, got the shorter versions this time
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
