Fixed! haha- aint no AWD-style understeering shenanigans here!
Wow did i mishear that? not inconceivable with all the engine noise and tyre screeching :P
oh and love your work Eric, pretty smooth and very atypical of a yank to downplay their work "oh btw heres a few random pics" and then bust out some of the most awesome pics i have ever seen from a track day.
Marulan is especially hard to get good shots from unless your prepared to go bush and hit some of the far corners of the track, you got some great shots of Skylines doing what they were made to do. Looks like there is a 33gtst s2 just like mine there too, at least on the dry day that you went?
Never driven there in the wet but had a few wakefield days while it was raining and for all the fun i find it far too unpredictable (and im not the only as evidenced by your blooper reel) whereas on a dry track you can really hone your skills and find out what the car is capable of.
Thanks for the heel and toe lessons but nothing beats practice, practice practice!
  • Replies 76
Also, further to Duncan's post, learning to correctly heel-and-toe early before you get into a corner will help with engine braking, taking some of the pressure (and therefore heat) off your brakes.
I find i like to use the extra engine braking caused by the spin up of the motor when i don't heel/toe (of course easing the clutch out so avoiding compression lockup of the rears) and I still get the regular engine braking you're talking about from the closed throttle.
I guess the only way to interpret this however, is that my brakes are too front biased, because I reckon my way of doing it gives me better overall stopping. If the brakes were better balanced the non-heal/toe would cause compression lockup on the rears.
Yep, wrong way around Dave, original post fixed ;)
Jarrad, almost certainly that noise is your gearbox thrust bearing. A bit of noise from it is no issue, just replace it when you get the clutch done. It may have been brought on by the day but it isn't urgent to address.
Adam, spot on, if you are using compression braking and find it helpful, you should have more rear brake bias. It's really just a bandaid for something wrong in the barke bias (because a foot brake will always be more effective and consistent)
BTW Eric....always have 2 hands on the wheels when you are planning a spin :P
is that expensive duncan??
pretty much determining weather to join the wakefeild day on how much itll cost to fix it.
You don't fix it until the clutch dies.
Most R32 and R33s have the same noise, just keep driving until you need a new clutch itself.
im pretty keen but i got no stockies and since i work in bluescope theyve cut all overtime, so trying to cut back a bit hah. if its raining i may come so i can keep my tires on.
well see :)
well see :)
well see :)
dude, i've got some you can fry. these guys still haven't picked up the stockies at my place so i've got 6 lying around. more than welcome to use them.
The GTR lives!
just got it back from CRD about 10 minutes ago and proceeded to drive it very sensibly with out any sort of erratic or unnecessarily vigorous acceleration all the way home causing very little noise pollution in my neighbourhood. Or the exact opposite of that, I'm a little hazy on the details.
Apparently it blew one of the boost pipes off and just blind sided the ecu's ability to tell how much air was actually going into the engine, hence the epic over fuel.
Anyway, good to go for the next track day!
The GTR lives!
great news Matt...you owe me a proper ride in that beast! Seriously, the flames coming out of the exhaust when i followed you in to Picton were epic
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
