Lol yeah mate big sigh for us both im hoping i might get the time to fab myself up a new cooler pipe tomorrow and if not i will get into it Saturday im gunna piss off that shit pipe that runs behind the radiator and shorten the run to the throttle body up! im gunna come up with something to pressure test my setup too gunna block off my turbo outlet and the pipe before the throttle body and put 35psi of compressed air into it and got to town with a bottle of soapy water to check for leaks so i know for a fact the bitch is gunna be right for next time haha! Glad ya got to have some fun in the beast tonight anyways jase lol all i got was more work for myself haha
Bugger, that sucks!
What is the rest of the setup on the car again? Is it a stock mount turbo etc?
Jason, not bad result still - would have been nice to see how it went with VCT etc though. How does it compare with the old car?
Yeah bit of a bugger lithium but got today off work more or less so im gunna fab up my new pipework and chase these damn leaks today so ill post some pics up of my new setup tonight when im done
Bugger, that sucks!
DW I feel like a half arsed POS too lol, I now need to decide do I buy a new VCT actuator for $450 or do I buy Brian Crower cams for under $400 delivered......... Tough choice.
Accordingly to Jezzup fixing the VCT wont warrant a retune but changing cam profile will warrant a retune. I also have NON VCT DE cams and gears I could whack in, cheapest option with a minor touch up on the tune..
Pretty happy with the result all things considered, the dyno sheet is on FB already if you wanna have a stalk.
The old setup (more or less the same but with a DET rather than a DE and also made 200kw) was a lot more sluggish. This comes on rather lively and definitely is happy to go. But for some reason high load (ie on highway) it seems to hunt a little bit when trying to accelerate between 2000 and 4000rpm.
I can only think it is attributed to the lack of VCT, and I'm hoping I'm not wrong. Am looking into cam specs between S13 and S15 DE's (i have a set of S13 DE cams at home to whack into my S15 DE motor if need be as stated prior).
Le sigh lol
Come on Simon. People dont fudge figures in sydney :rolleyes:
We Western Australian's do it all the time, we just didn't realise that you eastern staters were smart enough to work it out :whistling:
The best thing about is we have rigged our drag strip as well so our mph matches the power :nyaanyaa:
f**king LOL at huge reading plus "Temperature Probe Fault"!
Dyno Dynamics correction would be loving that :)
so a temperature probe fault gives higher readings? :unsure:
should ask my tuner to give me a faulty higher reading so i can join the 300rwkw clubz
i dont think its too unrealistic considering the factors involved
- we know these turbos really get going when you pump big boost through them
- 27psi would make a big difference compared to the standard 18-20psi... especially on the GTX series
- e85 is in the mix... ~15% more power right there
even it you take 25kw off the number.. 350kw is still very impressive
Lol Simon.
Dori yes that is how alot of people fudge numbers. PT have had that issue for years, they say it doesnt affect readibg
oh ok, well i've found out from a few ppl (including myself) that it is in fact true,
dyno run on theirs, read 20kw higher when tested on other dynos.
I don't think it's unrealistic power figure either... But does it actually make that power is another question :cheers:
if we take into account the whole dyno isnt reading right arguement then i dont see why it wouldnt actually make 350kw all day everyday
Epic, running 30psi?
edit: Running 12.1 afr??? hax
more details for us newbies please :)
Edited by usmair
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
