Thanks Dale yeah its what i do for a living mate but i would like to start doing more car stuff though as people tend to appreciate nice pipework under a bonnet more than in a factory haha hopefully ill get it sorted this afternoon and get it on the dyno sometime this week am keen as hell to push the lil GTX and see how many horsepowers she is good for
Looks like you're pretty handy in the fabrication stakes there Mick. Well done, now get into running this thing up with some boost into it. :)
Looks like my car wont hit the rollers till Friday night now id say :whistling:
Gives me a bit of time to get my pressure test done and weld in my point for the boost control pinch.gif
Hoping this turbo has more than the 320kw that some have predicted and considering that it made 312kw with boost pissing out of it while it was trying to pump 22psi down her neck so im hoping to see 330kw at least! Or maybe im dreaming haha but bring on near 350 i say!:thanks:
I reckon 335rwkw @ 25psi plus with all the problems sorted out :P
PS your pipework looks awesome. Wish I could do that!
Id be happy with 335kw lol hoping this pipework helps boost and throttle response as i think those boost leaks may have been hindering my response
Thanks Justo keen to start doing more work like this i enjoy it :thumbsup:
Hows ya ride coming along?
Thanks mate yeah bit the bullet and got rid of that ugly crap haha for sure mate always keen for a chat with a fellow enthusiast :)
Looks good Mick.. so glad you did away with that half peeled spongey crap piping.. Ill probably be working or hanging out at unigroup on friday arvo so be sure to say hi!
Not much progress unfortunately, crank is back at the crank place getting the crank collar fitted. Should have done it in the first place. :pirate:
Hey Mick_o, are you still running the "small can" 14psi actuator, or did you end up changing to the 18 or 19psi big can one?
Still running the 14psi can mate might try getting the big can this week actually forgot all bout that lol
Thanks sarge thats not actually a bad idea! Never even considered running it that way as i had my mind set on shortening up that pipe as much as possible but i like the idea of keeping the pipework outta the heat i think what ive done with my pipework would be less prone to heat soak as im nowhere near the radiator and there is less pipework directly over the top of the engine which should help keep intake temps down imo
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
