  • Replies 54
Posted Images
  • 11 months later...
  • 7 months later...
I thought i'd post here instead of start a new topic.
i'm thinking of asking santa (mum) for cam gears for christmas, as it's the only thing that's cheap enough. Just acouple of questions.
are there any diference in the brands? from what i've read it's sfa.
and is it a worthwhile mod with stocker cams? (the dyno pic dosn't seem to be working)
my mods are:
Power FC
3" cat back
big FMIC
13psi boost
i'm planning to get new turbos, cams, and those trust dumps when i get some more $$ next year.
I thought it would be worth asking for as it will save me ~$350, and will go with future mods.
Thanks
I'd be doing dumps before anything.
on an RB26 i would do the cam gears before dumps. a really nice set of dumps costs around $1000, and cost a fair whack of labour (or time) to fit.
personally i like the greddy cam gears, but they are all much of a muchness. there are really decent gains to be had on a lightly tuned RB26 with stock cams and adjustable cam gears. i gained 30kw at the wheels from cam gear tuning (both inlet and exhaust).
on the question of cams and cam gears, my mate had Poncams (IN/EX) and cam gears fitted to his car however the cam gear for the Inlet could not be fitted. I told him it may be because the Poncam's like to rely on the NVCS solinoid, therefore the cam gears can't physically fit on due to a different bolt spacing or what ever?...... is this whats going on?
  • 5 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
