  • Replies 54
  • 1 month later...
debadge the hamburger yes
the gtr badge on it's own does look good
Followed a black 35 the other day toward Eastern - rear spoiler removed and only a GT-R badge on the boot - looked good.
You took a car you own to a carwash that uses a sponge to wash your car???? :down:
Save the money and usually time, most of all your car's appearance, take it to a high pressure carwash booth and do it yourself. Better yet, buy yourself a karcher and do it from home. Then just use a clean chamois to dry it off.
as a hobbiest detailer i couldnt fathom having my cars washed by low paid indian students, but then again everyone has diff priorities in life and some have other things to do instead of busting out the karcher etc on a weekend
nor would i simply high pressure the panels and then wipe all the dirt into the super soft nissan clear coat with a shamwow
op if you want someone to look after your car, shoot me a pm, i can recommend you a mobile detailer in your state who will do an at home wash
Mario did your families cars???? He's pretty speialised in what he does.
I saw coppers writing up a ticket for a GTST parked in a loading zone outside Coles in Diamond Creek one night. It was after hours and a place where everyone parks, so I thought it was a bit tough.
Then I saw it had a GTR badge on it so I told them to book him twice.
had a R33 GTR back in 2000, sold it cos there was just way too many fake GTR's running around.
thank god that R35 looks vastly different to the V35............... even though there are still some attempts for the V35 owners trying to stain the GTR badge!
i think there are 2 white V35s running around in sunnybank with the badges....................
Edited by weber
True and yeah it is good to see the R35 GTR looking vastly different to a V35.
Fortunately, to the trained eyes of people who are familiar with GTR's, they can tell if it's a real GTR or not, even with the fake badge on.
I dont mind this
I only like to see this 'old school' GTR badge on the KPGC10 but this surprisingly looks good.
You sold your R33 GTR because other cars not as good as the gtr looked similar and had a badge on it????
Anyone who matters can spot a fake from a mile away (unless someone has spent a shit load of $$$ on body work on a car that isn't worth doing it to), and you really gave up the performance and satisfaction of owning an R33 gtr back in 2000 (which then was the equavalent of owning a 2008 JDM R35 in todays terms) because there was others that looked similar???
That is the type of snobby thought process of................... it doesn't make sense, they are all Datsun afterall :P
I miss my Datsun still (oh and it had a gtr front bar, no badge or anything else)
Hi every1, I have been looking for a nice r34 gtr for a while now but have not found anything yet. So I am starting to think about getting a r35 gtr instead.
But are all of the parts etc very expensive? Would just like 2 kno what im getting myself in 2.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
