dont be weak, get some real calipers that take 30mm thick pads! only have to change them once every year or so.. with track use.. and if a common racing caliper pads can be had pre bedded for less than 150 a set.
  • Replies 55
Posted Images
you tried these guys for DS2500s DJR? http://www.zeckhausen.com/Brembo/GT1_Pads.htm
pad choice for F40/F50s is probably second to none. all the euro stuff is available, so is the US stuff and even the japanese stuff is all made in F40/F50 pad shapes.
as far as the cool kids go, they most often mistake my F50s with 355mm rotors for stock R33 brembos... lol definitely no cred, especially since they fit under my 17inch LMGT4s...
From zeckhausen
The 16mm FDSR3028 w/o sensor slot is no longer available in the USA and possibly Europe, but the 16mm thick version with the sensor slot is available. I'm checking to see if it's sitting in the USA or if it has to be ordered from Italy.
Meanwhile, I've added the 16mm thick pads to our part numbering system with a "-1" extension to differentiate from the 18mm thick pads. See: http://store.zeckhausen.com/catalog/index.php?cPath=82_85
Will let you know about availability shortly.
For some reason, the thinner 16mm DS2500 is more expensive than the 18mm version, however the pricing is reversed with the DS3000, with the 16mm version being cheaper. Odd.
Then:
I just heard back from Essex - the importer of Ferodo into the USA. They state the FDSR3028H is not available and they do not stock the FRP3028H. It would have to be special ordered from Italy with a lead time of about 8 weeks.
I think I'm going to buy a set of the project MU titan HC for my F50s. yes they are 18mm but they list them as suitable for front calipers. maybe F40 to F40 is slightly different width? for $179USD I think they are pretty keenly priced.
Well let us know how you get on. Are they a new pad because I cant remember Project Mu doing something with that working temperature range. Local price is $444. Ow.
I think I will order the 16mm pads (and wait a bit) then check them with a 2mm spacer.
fk me dead. $444 is harsh. I thought $178 was cheap but was thinking more like $300-$350 retail. :( will let you know. if it comes to it I'll need to spend some time grinding the bastards down... :(
yes. 400 for little 16mm pads is horific. just think, 2 pad changes and youve almost bought a set of forged monoblock race calipers with titanium pistons.. fyi using evo pads in the f40/50 caliper lowers/widends the contact area buy about 10mm. but they are thinner.
Have you tried PFC06? They are a nice bitey pad, but in my car I struggle with locking brakes with them. I am abotu to bin them for some RS4-2. Much lower bite nad friction coefficient. I think some of the high u pads are for non boosted brakes etc
  • 9 months later...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
