http://www.ebay.com....=item4aae5f5131
"TURBO MOTOR WITH TURBO REMOVED FOR P PLATE FREINDLY CAR (IDEAL AS A FIRST RUN AROUND CAR)"
Feel sorry for anyone who picks this up without doing any research ...
Lol at the stagea badge
Edited by aussietroy
rare as f**k colour. has potential.
ill shoot him an offer when the dude picks up my wheels. im looking for a project :)
actually. just saw the interior. f**k that shit.
Edited by Mohsen
hmmm even worse, its been a drift car, take note of handbrake and two pod filters, so its had a turbo and been flogged....
and whats the bet its had a very recent conversion to auto....
if you look closely at it the wheels are 4 stud. that is a NA car as std so teh thing has the crap brakes and if hte engine WAS swapped probably a CA18I in the slot. . the AC controls are teh plain ones as well.
its good for parts and in reality not a lot of good for that.
Could have been an RB20E as well ;) My GTE came with the 'plain' ones ^_^
no?
in his ad he says it's a 'non turbo' but on the blue build plate it says 'rb20det' (you can also see turbo manifold if you look close)
he also says it's a '1998 build date'
he's confusing the size of the engine with the build day.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
