  • Replies 412
Kuhmo KU36's are worth a look as well a fair few people ran them last track day and were quite happy.
Just make sure you lower your tyre pressures down to about 30psi, it took me three sessions to get this right and i was running street tyres. My tyres were overheating and feeling squirmy after three laps. Reduced the psi and was doing 6 laps confortably. Was running Michelin pilots for reference.
Rsr and ku36 both great for buck. At the moment I'm running both. The rsr feels better but will wear faster. Ku still feel good and extra k's is a plus if its used often.
The r1r's that vu mentioned are not worth the extra few hundred each, in most tyre places their the same price as the r888. A great tyre, but not worth the coin
If your happy to shop online the dublop direzza star spec,hankook rs3 and yokohama ad08 are all great prices from tirerack.com
http://www.tirerack.com/tires/TireSearchResults.jsp?width=265%2F&ratio=35&diameter=18
not a fan of KU36's, i found once hot they slowly get shagged.
RSR or toyo R1R i would go i reckon Andy :)
Haven't had that problem myself. And I've done a few track days on my current set of KU's.
R1R's while being quite lovely, aren't worth the asking IMO. May as well get a set of A048's if you're spending that sort of coin.
another vote for KU36 beng great bang for buck :thumbsup:
Yep another +1 here for the KU's
I ran the KU36's on my setup last track day and got the times down to where I realistically wanted to. Just make sure that you run the tire pressure a touch low to start with as they will get some heat into them :D
maybe the driver got better?
Anyway, whats everyone's "got-to-do" list before track day? :)
For me; helmet, tyres
Fit cams, buy and fit injectors, buy and fit 300lph+ fuel pump, roll/flare rear guards, drop subframe to replace diff and subframe bushes, shim diff, fit LS2 truck ignition coils, purchase and fit new clutch, empty and clean tank, sort the brakes out, have new dump/front pipe and intercooler pipes made to suit new turbo, align, fill tank with E85, tune.
Not too much to do...
Once I'm able to work on the thing again, most of that list will be done fairly quickly.
My to do List:
change brake pads (Hawk HT-10's)
Buy Helmet
Oil Change
Might need new tires by then, i've got R1R's they're awesome tyres. very grippy, and pretty reasonable wear (just need to get pressures right otherwise they wear unevenly)
I'll probably go for the Federal RSR's next just for a comparison, i'm not sold on the KU36 because they're a-symetrical and i don't want to have to trow tyres out because of camber wear.
i think one paper RSR's are probably closer to R1R's wear and grip so it'll be interesting to see how they compare.
other than those small things i'm looking at lowering times by driving better, hopefully wipe a few seconds off my previous times. ideally this track day i'd like to go sub 1m25s
Fit slotted front rotors, 850cc injectors, fit fuel system, wheel alignment, fix seat rail from sliding, fit z32 afm, get hard intake pipe made up, mount ls2 truck coils and wire in, clean tank, fill with e85, tune.
I'm in. Just booked annual leave.
Assuming it's ok can I just confirm about timer closer to the day?
Before the day I have a heap of stuff to fit: Shift kit, brakes (rotors, pads, braided lines), coilovers, adjustable toe arms. If I get to it I might also get the eManage fitted and tuned. Also need to fix the undertray at the front >_<
My aim is to get the car up and running again.
Here goes my list:
1) Get the diff working
2) Check the brake pads and possibly repalce it if need be.
3) Replace all the fluids
4) Take time off work.
apart from that no real issues really :D
I'll hazard a guess that my to do list is the biggest.. (pardon the crappy phone photos..)
(that thing wrapped in glad wrap soon needs to go in the big empty void in my engine bay) :P
Mines about the same...I still need to finish assembling the engine however. But everything is beginning to come together and should be on the road late Sept/early Oct :)
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
