Hi All,
Just seeing how much people have knowingly gotten away with getting their cars inspected?
I ask as i need to get my Stagea inspected to get WA rego, I bought it from NSW.
It came with nice looking V35 rims in the photos.
The photos didn't show the wheel spacers, if I take the spacers off the back tyres rub slightly on the coilover lock nut.
I dont really wanna rush to buy a set of rims I dont really need while the tyres are still good on it.
I could probably drive it for one day as it seems to have 2-3mm clearance whilst stationary, must only rub on bumps or corners.
If others have got away with them on.....
Cheers.
Shane.
Lets see how long this thread stays open...
OP.
You're admitting on an online public car forum that you purchased a car that is un-roadworthy and/ or defectable by law and want other members to openly say how many Illegal things they have on their car and how they got away with it?????
OP.
Build a bridge. He hasn't murdered anyone.
I've only been over the pits twice, once on my XR250 which had a blown rear brake light and once in my 1600 which copped a few minor things which I had to fix, but nothing major. They ignored the non-engineered seats, 2L motor where a 1800 should have been and a whole bunch of other things.
My current car is dripping with unroadworthy things such as a Power FC, exhaust hanging a touch too low, boost controller but hasn't yet been picked on. It got through a roady no worries as well.
  • 3 weeks later...
"going over the pits" isnt a game. i dont want my loved one's lives at risk from un-roadworthy cars being driven on public roads.
And a car that is 5mm to low or vents gases to atmosphere is going to kill ur loved ones right??? get real....
its not as if hes saying, " hey my fuel tank leaks and my brakes dont work, will i pass?"....
News Headlines "SLIP ON SPACERS KILLS FAMILY!"... hahaha
Edited by BrynDETT
So nothing on your car Is "defectable" Adam?
If not then go Ahead and say that bold Statement.. If not STFU.
I agree fully on this statement above :) How many highly modified imports would pass if they went over the pits ? Not very many i reckon !! Whats the point of owning a import or any other high performance car without modifying , the world would be a very boring place !!!
I have found that I you make a genuine effort to do what you can and the cars not dangerous and your not using dodgey fixes and not takin the loss they will be reasonable.
I.e. Tint too dark will usualy only be picked on if it's realy dark but not If it's a little under the limits. Suspension done badly to get more lock or camber compared to aftermarket stuff or an exhaust made quiet by shoving something in it.
  • 7 months later...
I purchased my car from NSW and registered in QLD my mechanic only pulled it up on mechanical issues. It failed with severe excessive movement in the steering rack shaft. Got that fixed then whent to QLD transport and they didnt even look at my car they just took my cash and gave me the rego papers. :yes:
Almost owned my car for 4 years now (starting from my P-plate days) & never got sent to the pits.
Defectable stuff include the usuals suspects: high flow Cat, FMIC (steath return flow black one, although still had to trim the reo bar a bit), boost controller, SAFC 2, 2 gauges stuck onto the dash with double sided tape :whistling:, the brake light on the spoiler doesn't work (never did, but the other 4 works).
Got pulled over a couple of times for random license checks/RBTs, but the Police here never seem to care.
Theres a lot more un-roadworthy everyday boxes with bland tires, worn out brake pads, leaking oil etc etc compared to some dude with a Skyline that is too low, has aftermarket ECU or atmo BOV (even if it sounds wanker, it doesn't endanger anyone).
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
