  • Replies 40
Common problem, just changed to the shockproof oil a couple of weeks ago and sure enough I have oil coming out of the breather, never had this issue until this oil went in.
Is there a solution to this issue other than changing the oil, seems like a waste of big dollars to dump it for a different brand.
Might try contacting Redline otherwise.
Would be interested to hear what redline have to say about it. By the sounds of it there is something within the oil itself which is causing it to froth up, only solution really is to dump it and get another oil.
That is FALSE - Do not think that extending your breathers will fix the problem.
We extended them higher and longer. It still made it all the way up and 1L would come out on cruise but none on the race track. It was only ever on the way to the race track we would lose that much. It would still lose it in small amounts on the track but not even a fraction in comparison.
They are just avoiding the problem. We moved to a better oil, we no longer have this problem
Hmmm interesting. So what happens when it has "climbed" all the oil out of the box? You have to keep refilling it all the time? Sounds shifty, im still running the oil previously mentioned and have had not 1 drip come out of the breather that i can see.
Edited by joeyta22
Yes, we had to keep pumping it back in. Even when it was 1L down, it would still pump it out up 3M of hose that was half a meter higher than the factory point and spit another half litre out into our bottle
We use Royal Purple 75w85 in all the street car stuff and Royal Purple 85w140 in the race stuff
Or Motul Gear Competition on request
im assuming this is in reference to Max-Gear which is suitable for diffs (75W-90, 75W-140, 85W-140 1quart bottles)
for gearbox i only see Synchromax listed but no info on the weights available
also cant find anything on Max-Gear being suitable for LSD
Syncromax is different
Synchromax® is recommended for manual transmissions that specify an automatic transmission fluid or motor oil. It is also ideal for 4x4 transfer cases and / or 2-cycle and 4-cycle motorcycle gear boxes.
And yes - Max Gear is suitable for LSD
  • 6 months later...
Righto,
fears are confirmed.. THERE IS f**kIN OIL EVERY!!!, seems to only happen on longer trips EG 100km plus.. anyway
the redline light shock proof is absolutly pissing out the breather, not going to risk spending that much money again. Dont really care if it was a bad batch. Going to change to something else..
probably RP or Motul like Elite has recommended
cheers
  • 1 month later...
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
