SAU Nationals Road Trip
This is just an unoffical SAU cruise where we can enjoy the trip together and make a long trip much more enjoyable. The whole trip takes about 8 hours without stops so we will need to meet up early and leave strictly on time.
I've given about 15 minutes of buffer for each of the scheduled stops. The idea is that if you REALLY want a certain type of fuel or have to pee, then stop and meet us at the next location. We won't be stopping at each servo on the way to Yass. So between Pheasants Nest and Yass if you want to stop just meet up again at Yass. As long as you are quick and don't dilly dally you should be fine. We have two longer breaks - for meeting up in Yass and then a quick lunch & Pit stop in Albury.
What to bring:
Be sure to be prepared for a solid 8 hours of driving. Have brekkie before we meet up and have your sunscreen on - nothing worse than truck driver tan!
Also a good idea to have some drinks, snacks and a pack lunch as we won't have much time for stops on the road - just a quick potty stop here and there.
If you have a CB bring it along so we can chat along the way with an extra set or two of batteries. Most only last 4-6 hrs on a set. Or better if you have a ciggy adapter.
THE PLAN: Google Map Version (Link)
Sydney Meeting Point:
Starting Location: Pheasants Nest Mobile
Starting Time: Will leaving on Friday 28th October.
Meet up @ 7:00 for a 7:30 AM SHARP! departure.
We WILL leave right at 7:30 am so don't miss the bus.
Remember we are on a strict schedule to meet up with the Canberra people at meeting point #2.
Canberra Convoy Catch-up:
Starting Location: Caltex Truck Stop @ Yass off Hume Hwy
Meet up Time: Meet up @ 10:15 AM for a 10:30 departure.
Fast Fuel & Pit stop in Albury:
Arrival Time in Albury: 2:10
Activity: Fuel stop of choice and just a few minutes for lunch
Meeting Point: Aquatic Centre
Departure time: 2:30 SHARP! Don't be tardy!
Arrival in Shepparton: 4:40 pm
Now check into your hotel, have a quick tidy up and meet up for the pre-SAU Nats festivities!
Detailed Driving Instructions: (As from Google maps)
Mobile @ Pheasants Nest on Hume Hwy Starting Point
Shell Truck Stop on Hume Hwy (Optional) 55 km – about 35 mins
BP Truck Stop @ Marulan on Hume Hwy (Optional) 25.5 km – about 16 mins
Caltex Truck Stop @ Yass on Hume Hwy 114 km – about 1 hour 13 mins
Yass to Albury on Hume Hwy 302 km – about 3 hours 41 mins
Albury to Shepparton via Hume Freeway 173 km – about 2 hrs 7 mins
Sydney Meeting Point - Mobile @ Pheasants Hill
Canberra Meeting Point - Yass Caltex & Maccas off Hume Hwy
Albury Meeting Point - Aquatic Centre Car Park (End of Hume street)
The Trip Route:
  • Replies 127
great burgers? +1 for amending trip to include these...
great work Eric, are you still going to try and shoot this video along the way? how about some twisty bits thrown in?
just m 2cents, will be there either way.
Video of trip down & along the way - Yes!
Twisty bits, well it's a long day and if we want to take an extra hour for a burger stop (I'm in favor too!) then we won't really have time.
But I may ask a few folks to take a go-pro and "talk to the camera" a bit on the way down.
Last time we did a large drive to shepp (about 20 people) it took SO LONG because of stops and bullshit - my advice would be to do the touristy stuff on the way home if it needs to be done, that way anyone who's not interested can just keep on going and also there's no rush to be anywhere because the event is over :)
i just bought a driftcam pro, can also contribute a go pro HD and two handycams if that helps :)
really should go pay for my trackday tickets too for this thing..as for twisty bits, fair point with distance we are going. we are going to at least sit on 119km/hr on the freeway right? will save us at least X amount of minutes over the day...:P
I have to update the trip. New plan is to have lunch at the half way cafe instead of in Albury.
We'll still have a fuel stop in Albury but meeting point will change. I'll try to figure out our timing for you Humbla - but given the number of cars and length of the trip, I don't know how accurate will be. PM me your cell number and I can SMS you from one of our stops.
Ok so last night started to update but stupid windows update crashe my machine! ARGH!
Will update by the weekend.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
