Hi
Im no expert on boost but as far as i know if u have a turbo car, any turbo car, and u want to add boost ( which is fine within limits) shouldnt there be a few other things to do first?
My mate just bought a stock Ford XR6 Turbo... :( not my choice but all good) So the first mod he has done today is add boost......
Shouldnt he add an upgraded intercooler first ? as the turbo will now run harder with boost, he should replace the factory fitted cooler to a larger after market one? and shouldnt he add an upgraded exhaust to cope with extra backpressure, and mebbie even wastegate?
Im not sure how much boost he will run, but i can see a disaster heading his way without other mods to cope. I argued he should do the other mods FIRST to which he says nah all good, so i advised him to run under 10PSI if he isnt doing any other mods.
Any advice is appeciated, thanx u.
Edited by nathanau
Xr6 boost is controlled by the ecu. Im curious to see what happens.
Best to just get a tune.
Hmmms well im curious to see what happens too lolz i can just sense something melting or blowing up..... My mate has Zero knowledge about cars other than to change gears etc.... He wouldnt even know how to operate boost or what PSI is..... he said one of his mates is installing the boost .. some guy who just runs rats on the road...
My mate is into his xr6 turbo first thing first is get intercooler piping done. The stock plasticpiping is designed to burst at anything over stock then tell him to get a flash tune. Stock intercooler is fine for up to 400rwkw
a better cooler and exhaust would have given him more power on the stock boost than turning the boost up a few psi with nothing else done to the car.
Hi dude, yer that sounds like a plan. But he is just running after market boost now, and im guessing its going to be 10 ( knowing his mate) or over 10psi..., without any other mod... and no tune, nothing else.
Edited by nathanau
It will have a fit and the car with do stupid shit. The xr6t is unable to have things like this done because the ECU protects everything.
In other words, only way to raise boost is with an edit.
Looks like he's going to learn the hard way. Tell him to put a big vent to atmosphere bov on there too.
Do not boost using a boost controller will cause problems like leaning out which can cause his motor to blow
heya , yer thats kinda what i figured, i already told him to expect this, but i also wasnt 100% sure, but its gotta be logical, for every extra bit of output you add, there has to be an upgrade to cope. Ill find out tomoz how it all went, i know they did the work this afternoon.... I wonder how then they got around the ECU....
I told him to add that but he was like " nah i dont need that" lolzzz i was like Grrrrr! But im not an expert so i figured id ask more knowledgeable ppls here :)
You can't get around ecu tried it on mates xr6 tell him best bet is go see a tuner that deals with xr6t's my mate got a stage 1 kit done for 2k including tuning which was bigger injectors metal piping and flash tune gained him 80rwkw
Thanx dude, shall be passing all these comments onto him. I told him to at least join some forums first and as some questions and read. but nope I cant tell him .
anyone know where i can buy more boost so i can install some on my car? cant seam to find it on just jap....
Yawns.... more for his benefit than mine... but i did make a post re Turbo Timers not been safe for car theft... u can comment on that :)
http://www.skylinesaustralia.com/forums/topic/376892-trubo-timers-not-safe-for-theft-of-car/
Edited by nathanau
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
