Does any one have any dyno sheets or any thing with turbonetics turbos.
Im trying to decide what to do,Either turbonetics gtk650 or a t04z.
Computer is a apexi
I run 98 due to the fact i dont have e85 where i live.
Due to turbonetics not making a 750hp turbo or even 700 in the turbonetics range i have 2 options that way gtk650 or gtk850 or t04z
My motor is stock atm i like response due to having hks2530s atm but not enuff power.
Chasing around 500 hp to 550hp on pump atw for my gtr.
I have a set of 264 cams already comming but it looks like a turbo let go on my gtr.................
Can any one please post some dyno results or some thing to help me out.
cheers keiron.
Get another 2530 then cause they should have no dramas getting 550whp and will be the cheapest option vs a single conversion.
If you can't crack 550whp on 2530's check your current setup before changing turbos
gtk is all well and good. but not that good. half ball bearing with a fansy paint job and ported comp cover. i was going to get one (the 850) but i could not find much info on the results as many people prefer bw or garretts.
You would be hard pressed getting 550awhp with his setup without BIG boost.
I know of a GTR with 2530s making 530awhp at 22psi on E85.
Ok then taking big boost out of it (come on 20 psi is the start point ;) ), let's say he goes for the bottom end of his goal, here's a result from page one on the dyno result thread. 2530's are bigger than 5's and I can't see 2530's making less than 5's-we all know they can make good numbers :)
Back on dyno for cam timing adjustments.Power went from 351rwkw to 368rwkw.
HKS 2530's
Nismo 600cc inj
Power FC
HKS 264/264 cams
HKS ebc
Z32 AFM's
Trust cooler
Stock bottom end
Tomei fuel pump
Anyway good luck with whatever you end up doing OP
Im running 1.6 bar or so atm with 25/30s and my tuner told me i wont make any more power on them on pump.
Sorry i was messed up when i posted last night i had been up all day was at powercruise and had to drive 4 hours home.Id like to make around 500 hp atw
On a hub dynopak i made around 470hp,
my set up is this
apexi power fc
hks 2530s stock manifolds
hks electronic boost controler
2x rb25 green lable afm
040 in tank pump stock fuel lines (not run out of fuel yet)
700cc injectors
mines sports div dumps into a veilside twin front pipe 5 inch body balistic cat. my exaust for the most part seems to be twin 3 and a half inch
greddy cam gears
When i come on boost is real responsive i just charge our infront of most stuff.
Now when i come on boost she spikes out to just over 1.6bar then slides back down to 1.4-1.5 bar,
Can you post your dyno sheets of the 25/30s mate making around 550 hp at all 4s please.
here is my old dyno sheet.
cheers keiron.
Edited by Gtir-keiron
+1
i been on the phone all morning i think i have come up with a solution.
I already have a greddy twin afm front pipe and a bran new turbosmart 45mm gate in the box.
Talked to a few turbo places this morning and 3 of them said as good as to4z are they are out of date tecnolagy and i should look at something more current.
Few places said gtk650 is too small and will not be what im looking for.
However i have been told that the new gtx garrett range of turbos would be the way to go.......
so im looking at a gtx 3582r .82 rear rated at 770hp,what do you guys think about that.Spool imports said they have had great sucsess with these turbos comming on early and making better hp at lower boost.
Should see 500 atws on pump no problems with the gtx 35r.
Any one else seen these in action.
i think i might have a fuel problem tho,Some say you can make 500 on stock lines with a uprated pump some say you can not.
Im running a 040 intank and have not run out of fuel while tuning with my 25/30s at 470hp or there abouts so i guess i can only try.
I think you should read the 10+ page thread on GTX turbos, there really are no results that support more power/earlier spool. And they all require a gut load of boost as well to do anything.
Can tell you right now stock fuel lines are fine. Seen many hit 400-440rwkw using stock lines.
I had the GTK850 on a 2.8L, made 760hp on engine dyno @26psi, so they certainly do make a 750hp turbo, it is a sexy looking turbo, but even on a 2.8L all the power is above 4500rpm, now running a TO4Z on the same setup, makes slightly less @ same boost but comes on at least 500rpm earlier, also ran those numbers with standard fuel lines, and 3" exhaust between dump and centre muffler...
keep your 040 in tank run a 044 with a surge tank + 6boost manifold + 45mm gate + 2xafm + cams, 20-24psi and see 500awhp all day!!!
Why put a surge tank in? It's not needed at all.
I'm just running a Nismo intank, as are most other GTRs down here, all tracked on semi's too.
Given he has a stock motor, there is much more that you'd be worrying about and not tracking it for a start
throw the 040 in the bin, get a s300sx 63mm :) (putting a s300 66mm on annas rb25 atm, will see the differance compard to the t04z its replacing.
There an echo in here? :)
make sure you post up the results, I'll be very interested to see..thumbsup.gif
could not have said it better, laggier and require more boost to do the same job.
i tried to read the gtx thread and omfg all it is in 50 f**kin pages is people spewing rubbish.
I found 1 guy who had posted up sheets of his old and new turbo.
This site used to be very helpfull but now all you get is people who tell you what not to do with short answers that help no one.Every one seems to know best but no one posts up any proof.
I come here to find out the best set up for my car to make the sorta power im looking for with some response.
I dont want to rebuild the 25/30 and try again to fail again on pump fuel,I want to change to a single but i get mixed msg from every one.Skylines australia used to be such a good comunity with people who were only too happy to help but now you get alot of people who mouth off and are stuck up assholes.
f*k this really
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
