Just a bit of news. Hit 71.4kg last night on the scales. Looks like I have finally broke into the 70kg mark.
Managed to do incline bench last night with no pain in my shoulder. Moved over to Chin ups and the pain came back with a vengence. Stopped before I finished 1 rep.
The workout I am currently doing has three phases to it over 9 weeks. Basically 3 weeks of growth, 3 weeks of strength and 3 of overall conditioning.
When you say clicking what do you mean? I know when I do some exercises I feel a bit of a click in the shoulder but there is no pain. Example of that is machine shoulder press, my spotter needs to help my left arm drop the weight back down completely, this however does hurt if he doesnt help. However this same thing doesnt happen with dunbell shoulder press or military press...
Will post some of my lifting logs soon.
Like I said rotator cuff injury.
You are only going to make it worse. There are lots of other sympathetic injuries you can develop once you have this injury.
Leave the shoulders alone mate , till a physio says you are right to get back into anything thats using them.
The machine shoulder press and all that gaff needs to be left alone for you. Till you fix the injury.
Then you need to strengthen the rotator cuff muscles.
Clicking is something a good physio will diagnose. My guess is one of the shoulders is being pulled forward by tightness in the front delt/chest muscle connection point. You will have a big knot there most likely. Lots of causes sometimes bad posture , things like sitting at a desk / using a computer mouse and slouching.
You can test the shoulder injury by getting someone to press a thumb into the muscles in between and around your shoulder blade on the sore side. Go to a physio. It won't get better by itself, just worse.
If you start developing your shoulder girdle strength first and continue to keep it up. You will find bench and other pressing movements will have a much higher potential and a lower risk of injury.
My tip is leave the whole bench press and bicep/tricep curl stuff for when you are strong in the shoulders,back, core and legs.
So my shoulder has been getting better, pain seems to be going slowly so I am keeping a close eye on it, icing if it gives me any issue and lifting lighter.
The workout I have been doing is a 3 phase workout over 9 weeks. Designed to hit all aspects of training - general size, strength and conditioning. After night one I have seen good gains in my lift just about across the board except on my shoulders where I had to go lighter.
Before:
Bench Press: 50kg x 10 reps
40kg x 10 reps
40kg x 10 reps
Dumbell Incline: 10kg x 10 reps
10kg x 10 reps
10kg x 10 reps
Machine Flys: 37kg x 10 reps
37kg x 10reps
39kg x 10 reps
Dumbbell Shoulder Press: 12.5kg x 10 reps
12.5kg x 6 reps
10kg x 8 reps
Dumbbell Lateral Raise: 4kg x 10 reps
4kg x 10 reps
4kg x 10 reps
Last Nights Lifts:
Bench: 50kg x 10 reps
50kg x 10 reps
50kg x 8 reps
Dunbbell Incline: 15kg x 10 reps
17.5kg x 8 reps
17.5kg x 8 reps
Machine Fly: 45kg x 10 reps
52kg x 10 reps
52 x 9 reps
Dumbbell Shoulder Press: 10kg x 10 reps
10kg x 10 reps
10kg x 10 reps
Dumbbell Lateral Raises: 6kg x 10 reps
6kg x 10 reps
6kg x 10 reps
So if anything I am lifting more this time around so the workout is doing at least something. I do realise that I have to get stronger in my shoulders, hopefully when this discomfort leaves I'll be able to hit it hard again.
Cheers,
Cheers,
One big factor to being successful in the gym.
Attitude.
Attitude to your body needs to be right.
In the gym you inflict controlled damage the body. The word is 'controlled'. Right now your attitude is not in line with that. You are pushing through an injury, a weakness in the muscle that is taking control away from other movements it's involved in for stability.
That injury you have is rotator cuff. It's not getting better. I won't without help.
If you are unlucky , the next time it goes you will need surgery. Keep this up and it WILL go again.
The reason physios see so many guys like you is that you don't have the attitude right and when thats out you don't listen to the body.
It's a critical skill. Listening to the body also improves the focus in a workout.
There is no sporting title at stake for you. Why permanently stuff your shoulder?
Edited by rev210
As long as you have a good technique and the exercise isn't making the pain WORSE than it was, then I say it's not such a bad thing to just work through it and ignore the pain. Now I don't really like saying this, because it's counter-intuitive and you can't always get away with it. You really have to know your body well to know if it's the kind of injury you can just work through. But if it is, your joint will still heal, and sometimes for the better IMO. There are benefits to mobilising joints that are/were injured, as opposed to immobilising them and then putting them through their paces after healing (injury can come back easily if the joint did not heal around the movement).
How bout that :)
How bout that :)
Birds, it would be good for him to get qualified advice on his injury (which he still has if he's in pain).
I'm not pretending to be a physio or a doctor. But, I am suggesting expert advice is the way to go for injuries. We should support this notion first.
At the very least look the injury up, if there are concerns about wasting money on consults.
Speaking from my own experience with it, rotator cuff injuries may not present painfully. They can continue to increase in trauma without noticeable symptom as well, this is a fact of them.
However, if there is even slight pain then there is a sure fire marker for the injury to continue to increase. Therapy will not involve pain like this to treat the injury.
My 2c
I don't disagree it would be a good idea for him to see an expert about it, be it physio or doctor, but I do trust him to know the pain better than you or I could diagnose it over the internet. We haven't even seen him point to where the pain is. Pain is the body's way of you monitoring what, if anything is wrong with it, thus I recommended he pay close attention and test the grounds with it...not every joint pain means an horrific and chronic injury is on the way if you don't stop the exercise...it can be a matter of conditioning and sometimes you can get past it while the body does it's thing.
Birds, his description of where the pain is ,when it occurred and his trouble with clicking and pain in assisted press movements is sufficient to indicate possible rotator cuff injury. Due to the nature of this injury pain measurement by the patient has no real bearing on their ability to manage the damage if they continue to train.
We must be careful as 'testing the grounds' in so far as continuing with weights, with rotator cuff and many other skeletal/muscular injuries causes further degeneration.
The advice is harmful to people.
If he has this injury, a mild case may require a 4 week or more recovery. These injuries can take even longer to heal, setting you back over 6 months is not uncommon.
Many muscular injuries are self managed by people where they ideally could be fixed before becoming permanent. The gym is a place where bad attitudes keep surgeons in good money.
In terms of " not every joint pain means an horrific and chronic injury is on the way if you don't stop the exercise...it can be a matter of conditioning and sometimes you can get past it while the body does it's thing."
Joint pain isn't serious when the Doc/physio says so and clears you to go hit the weights.
I'd like it to be something less sinister for his sake. I'd love to be wrong. But, I am pretty certain about this one.
There's a lot of truth in what you're saying rev210, but even when you see a physio they clear you based on what info you as the patient provide them. They understand the injury and what's going on, but they rely on your feedback of "yes this movement hurts" or "no that was fine" to clear you to lift weights again anyway. Seeing the physio/doc isn't a must as they can only tell you what you want to hear, but I will agree with you that it would be stupid not to at least take a week or two off. Listen to your body figjam, pain is its way of telling you something is wrong so take a week off of upper, then see how it feels. I too have a shoulder injury related to my rotator cuff (comprising of torn stability muscles around the joint) and I've had the last week off already. When I say week off though, I don't mean you can't gym at all. This time off of upper body has been a great way of improving leg and core strength, targetting legs every second-third day, and core on the days in between.
  • 2 months later...
due to recent discussions I decided that I should probably update this...
shoulder injury seems to be all but gone. No more pain at least, but when I do some exercises (incline flys for example) my shoulder more burns, when this gets a bit much I stop, no use re injuring it. As a result my upper body lifts have gone backwards, but I am starting to get them back.
Workout has again changed. The guy I train with likes to do this for some reason, I thought the Tri Phase routine was working well, so we have modified that so to speak. We are also going near 5 days a week and working each body part separately.
Logs from before the Change:
Deadlift:
80kg X 8 reps (no wrist straps)
110 x 10 reps
110 x 6
110 x 5
Barbell Bent Over Row (dont really like this exercise, I am not real comfortable doing it so I could go harder but dont. It is also largely subject to availability of the barbells.... anyway its more laziness then anything):
25kg x 10 reps
25 x 10
25 x 10
Cable Seated Row (i was doing more then this awhile ago, but my form really dropped, so now i focus on form and really squeezing the back):
60kg x 10 reps
60kg x 10 reps
60kg x 10 reps
Cable Pushdown:
18kg x 10 reps
18kg x 10 reps
18kg x 10 reps
Pullups:
8
6
6
Barbell Curl:
25kg x 10 reps
25kg x 10 reps
25kg x 10 reps
Dumbbell Bicep Curl
10kg x 10 reps
10kg x 8 reps
10kg x 10 reps
Bench Press:
50kg x 12 reps
60kg x 8 reps
60kg x 8 reps
Incline Bench:
40kg x 10 reps
40kg x 8 reps
40kg x 6 reps
Cable Cross Over:
15kg x 15
20kg x 10
20kg x 10
Machine Fly:
45 x 10
52 x 10
54.3 x 10
Dip Machine:
40.8 x 10
42.5 x 10
49.9 x 10
Close Grip Bench:
20kg x 10
40 x 8
30 x 10
Machine Tricep Extension:
15kg x 15
25 x 12
25 x 12
Barbell Squat:
80kg x 10
100 x 8
100 x 10
Lunges:
10 x 10
10 x 10
10 x 10
As a note, I have been doing more then this, but this is the latest log that I am working from.
Leg Press:
170kg x 10
170 x 8
210 x 6
Leg Curls:
59 x 10
59 x 10
66 x 6
Standing Calf Raise:
60 x 10
65 x 10
65 x 10
Seated Calf Raises:
120 x 10
120 x 10
120 x 10
These are old logs. I will update this in a week to see how I have improved.
My Measurements:
Waist: 31.7cm
Chest: 35.9
Arms: 11cm (puny)
Forearms: 10.9cm
Shoulders: 43.8 cm
Thighs: 19.3
Calves: 14.4cm
Neck: 15cm
waist would be inches... other are right. Bit embarrassing but I seem to have real long limbs which I think makes it a little harder (not impossible) to get bigger round the arms and legs.
My spotter has much bigger biceps, but in length wise my biceps are much longer, same as my forearms. I should be a praying-mantis...
also my rep tempo is as slow as possible with heavy weight 8-10 reps. Aiming for 30-45 second sets with a minute rest.
Im a skinny guy mate, small frame. thin limbs, its going to be a while before I get thicker. specially my diet being the way it is.
Yeah there's no way we're on the same page here... 11cm really doesn't sound right, that's thinner than my wrist.
Measurements such as biceps are circumference - ie the distance around the limb, easiest to measure with a string.
How would you suggest it's done? As PT's, we do girth measurements in cm around the limbs, etc
did you read his measurements?
My Measurements:
Waist: 31.7cm
Chest: 35.9
Arms: 11cm (puny)
Forearms: 10.9cm
Shoulders: 43.8 cm
Thighs: 19.3
Calves: 14.4cm
Neck: 15cm
Take out your measuring tape and put your finger on 32cm.
now loop the end of the tape over to it to create a circle.
does that look like a waist size?
11cm arms?
That's smaller than making a cirle with your thumb and index finger.
obviously they are either INCHES or not measured "around" the limb/part but from one end to the other or some weird shit.
It's like measuring your wang but measuring just the head... we all know the measurement of our wangs starts at the gap between your a-hole and ball sack. amiright?
look at the tag of your pants..
does it say 32?
that's inches.
edit - you wrap this around your limb
Where the tip touches the tape around the other side is the measurement (in the case of this pic it is in cm).
Some tapes have cm on one side and inches on the other.
Edited by TTT
