  • Replies 68
Posted Images
NSX is starting to look a little old in the tooth, don't get me wrong I would still love one but compared to this
it does look old fashioned.
EDIT: Keeping in mind that the above body kit costs around $20,000 lol
Edited by Alkatraz
The NSX was a game-changer. It forced the likes of Ferrari to actually consider delivering a decent vehicle rather than the mostly appalling crap that had to date.
It was a special period for Jap cars, the Lexus was born, the GTR re-wrote rules, and the NSX made a Supercar usable daily and reliably. And don't discount the NSX as a Supercar, on it's day it most definitely was, despite only packing a V6.
thats the one with the 4cam 32 valve engine right?
If so yum
What the one with the Lotus engineered heads in the motor? As if Lotus know anything at all about engines other than how to fail timing belts and burn oil.
As for the NSX looking old in the tooth - ofcourse it is. It is a 20 year old design. Atleast it was never really fashionable so misses out on the period peices - although the full width reflective strip on the rear is very 80's.
nah mate, come on, they're good things! The engines were cast and assembled by Mercury Marine using then-new lost-foam technology.
I'd LOVE one! (although I'd throw up every time I got in it, the interior is awful).
The block is alloy as well and nothing is common to other 350 Chevs. You cant bolt the heads to any other block etc, all they share is the capacity with other 350s. I would kill for one, and the later model interiors of 1900+ are better then the 89 ZR1s which had the old square dash. For that matter then 89 ZR1s only had 385hp, so with the better interior you also get 20hp more.
vs
yeh, ok still a pretty horrible interior no matter what year model :)
And its a Cosworth Chev...so a good thing. If it was a Cosworth Ford then it would burn oil and all the fluff you associate with POS Fords :)
Yeah I know. I was just shitty because only yesterday I was looking at a series 8 and realising I could actually only ever fit into the fat shtbox Corvette parked near it.
how did we go from an underpowered road car with sublime handling setup by one of the most famous F1 drivers ever... to an overpowered yank boat engine with $5 of scrap metal bolted around it and no brakes!?
actually f*ck that, what I really want to know is why can't I get my hands on either one at a reasonable price in Australia!
Fair question.
I guess the NSX's are expensive because they have held up well and are a cut above the usual Honda/Toyota/Nissan/MItsubishi offerings.
There was once a really good video of Senna trying out an NSX at Suzuka (I think) The way he used the throttle through the corners was damned impressive. Worth looking at if anyone can find it.
is that the one where he's driving in loafers and they have the camera on his feet?
the way he drives the car... so laid back but absolutely balls to the wall at the same time... loose but fast, love it
Yeah that is the one. His driving was brilliant, his dress sense - notsomuch.
I had it stored somewhere (pre Youtube) but cant find it now.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
